85 302 Ho Swap To 79 F-150
600 CFM Edlebrock... Performer RPM Intake... Roller timing chain... Would like to know if a Crane Power Max Hydrylic roller cam might be the right choice, even though it is for computer run vehicles, Will this make a difference? Also, will my firing order change because of the up grade from stock? Last but not least I would like to keep some bottom end torque because I will be adding some helpers to the rear springs for pay load, in turn some high end for the want to she what shes got for kick down mode.... By the way this is all inclusive for what I bought for $700.00 . Including a fabricated wiring set up from hel.!!! a broken hydyaulic roller lifter, which distroyed # 8 intake lobe... a flat rocker for #5 intake for a replacement of a roller rocker.... But I am glad to say that even with all the chuncks of roller lifter, and needle bearings in the oil pump filter and the bottom of the oil pan I have no damage to the guts or the cylinder walls thank you for support
LindenBruce
03-10-2010 08:57 AM
camarokid81
11-04-2007 09:46 AM
JBradley500
33
10-25-2007 01:08 PM
