flat or angled blocks
I can't seem to find a definite answer on whether I need flat or angled rear blocks. Some people say to use a flat block and shim down the carrier bearing, others say an angled block makes it so you don't need to shim anything. The truck is a 4-door long bed, and I want a 5" rear block if that matters.
Apparently every Truck can react differently, I recently put a ProComp 2.5 front / 2.0 rear Lift Kit in my 2006 F250.
I exchanged my rear OEM 2" Flat Blocks for some 4" Tapered Blocks (did drop Carrier Bearing a little too) & the truck developed a "shimmy" while accelerating. Long story short i was sure i needed Flat Blocks due to my new Pinion Angle & ProComp argued saying they needed to be Tapered. After i followed their suggestions & emailed them some Pic's, I finally got them to send me Flat Blocks which corrected my issue.
Here's my Pic's (remember your truck may react different) but i needed Flat-Blocks....
sandman3510
1999 to 2016 Super Duty
01-24-2012 12:17 PM
2 stroke man
34
07-15-2009 12:08 AM
