jet size for old holley
02-23-2014, 03:40 PM
on
I recently put an old Holley 4160 650cfm Carb on my F100, due to the constant problems I was having out of the motorcraft 2bbl. I am going to soak the Carb and rebuild it and I was wondering what jet size I should use. Its going in a 78 F100 with a stock 302 with 340,000 miles on it. Thanks.
02-23-2014, 03:55 PM
No one can tell you what size you're going to need. Altitude, air cleaner type, emissions setup, ring wear, along with a host of other factors will affect your ideal jet size. It's going to be trial and error on your part.
02-24-2014, 07:40 PM
on
Can you give me a good size to start? It has no emissions mods on it and im running a spectre filter about 2in. tall and 5in. in diameter. Altitude here is around 2000* i think. I have no experience with jets, this is my first go at a holley.
02-25-2014, 09:37 AM
I think the Holley 4160 models came stock with 61. You might want to try that, but at 2K feet, mebbe a 58 - 59.
As Devino246 mentioned - trial and error.
02-25-2014, 08:52 PM
It largely depends on your power valve.
02-26-2014, 12:43 AM
on
Try calling the Holly tech line .
You shouldn't go too lean .
02-26-2014, 12:14 PM
My mistake - stock jet size for a 4160 is a 68 but I'm runnin' a little bigger, and at 500 feet. Please excuse.
The best idea was mentioned by 410 Highboy - call Holley.
WOODY863
05-30-2017 04:28 PM
Kuskoal
03-30-2008 12:48 AM
jsutton
03-05-2007 08:05 PM
MRStace84
09-25-2004 06:51 AM
Rat wagon
03-22-2003 02:24 PM
