Help, Need to be Thinner to drive my 69
Hello to All, Newbie to the Bumpside forum, Spent 9 years working on a 78 F 150, 4 x 2 , C-6, 460 and just got a new to me 69 F 100, 4 x 2 , 360 F E , C-6. Pretty straight old truck, been parked in a horse barn since 1988. Here is my question, I am a short, stocky fellow and there is no room between me and the steering wheel when I have the seat slid all the way against the gas tank. So if I remove the tank and put it between the frame rails will the seat go futher back than stock? This truck has manual steering now but I am going to convert it to power steering soon as I find a donor truck. My wife says just loose weight. Also is the Mustang gas tank the best fit? I really love my 78 but was hoping the 69 would be my all weather truck.
on
I went from buckets to a bench because I was sitting too low, and had real issues with how high I had to lift my feet to get to the brake and clutch (manual brakes, so lots of travel required).
Since I'm tall, the seat is all the way back and my problem was with new upholstery I had no room between the top of the seat and the wheel to get under it. Went from the 17" to a 15" wheel. don't think it will help with depth!
I went to great extremes to add more room to the inside of my truck. What I did made a HUGE difference and I get compliments all the time on how "big" the cab of my truck is. Basically, I removed all the spring structure from my seat, fabbed up some sheet metal inserts, and used modern foam for the cushion. I used 2 inch foam on the bottom and 1/2 inch foam on the back. It feels like a modern car now when you sit and really opened up the cab. I also moved my steering column forward one inch and I will be using a Econoline steering wheel. They are about 2 inches "flatter" than the stock f100 wheel.
on
BTW - I don't think this will hijack the thread - a buddy of mine with a '68 told me that he had seen somewhere that someone was making a wheel that looked like a stock FXXX wheel but it was only 15 inches. I have a Grant wheel in mine and it is ok, but I'd really like to go back to a stock looking wheel.
Anyone heard of this?
