Another carburetor question - Ford Truck Enthusiasts Forums
Old 02-22-2014, 08:47 AM
69'er 69'er is offline
69'er is starting off with a positive reputation.
Hoping for a few more good responses like I received on my last issue! Thanks again all! 69 F-250 with a recently rebuilt 390. Timing and dwell are spot on. The carburetor is a Motorcraft 2 bbl factory rebuild. I've checked the wet fuel level while warmed up and running and it's good. The motor has not backfired since the rebuild. It started up and has run smoothly since it was first installed. It starts and runs great when it's cold. The problem is when it has been shut down after warming up and I try to start it again. Then it requires a lot of cranking- like it's flooded. However it is not flooded. Also sometimes after it's started and I begin to drive it will stall out and again be difficult to restart. It also stumbles a bit on taking off from a stop or accelerating from a low rpm. No doubt it's something simple I'm overlooking but it has me bumfoozled! Any suggestions would be much appreciated. The old truck has been my primary transportation for 25 years and I'd like to have it healthy again!
Old 02-22-2014, 11:46 AM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Sounds like not enough fuel getting to the carb once the engine is hot. This could be plugged fuel filter, weak fuel pump, or vapor lock. When it stalls I bet if you look down the throat of the carb and work the throttle you won't see the accelerator pump nozzles squirting any gas like they are supposed to.
Old 02-22-2014, 02:20 PM
Ok, thanks Jeff. I have a new filter that I'll try first. It makes sense. The pump is only about a year old but nothing would surprise me.
Old 02-22-2014, 06:29 PM
Well, it's not the filter and still am not sure about the pump. It is delivering fuel during the slow start-up but it's possible by the time I pull the breather that the pump has recovered. I'm doubting vapor lock. It wasn't a problem prior to the rebuild and this can happen after a 5 mile drive in very cold weather. I believe the pump is getting a good fuel supply judging from the flow when I disconnected it before removing the motor. When I have a few minutes again I'll disconnect the carburetor and pump the gas into a container to see how that goes.
Old 02-23-2014, 07:03 AM
Rasputin53's Avatar
Rasputin53 Rasputin53 is online now
Rasputin53 is gaining momentum as a positive member of FTE.Rasputin53 is gaining momentum as a positive member of FTE.
When it's warm and you try to restart, do you give it a pedal press or just turn the key?
Old 02-23-2014, 07:55 AM
I just turn the key Rasputin unless I see that it's not going to start. In the beginning I tried about everything knowing I'd have to adjust to a new carburetor. If it hasn't set too long after turning it off it will start right up. After maybe 10 minutes it's anyone's guess what it will do.
Old 02-23-2014, 02:56 PM
Matson3719's Avatar
Matson3719 Matson3719 is offline
Matson3719 is starting off with a positive reputation.
I had a similar issue...turned out to be a bad coil. I thought it was the carb-but as that coil heated up in a few minutes-stall out. Never could tell when it was going to fire up again.
Old 02-23-2014, 04:10 PM
Thanks for the reply Matson but I don't think it's a coil getting heated up. The truck will always start but at certain times it just takes longer. I've had bad coils in the past too but this is different. Once the truck is running it doesn't stall except once in a great while it will stall shortly after a difficult start-up
Old 02-24-2014, 06:38 AM
Rasputin53's Avatar
Is it an automatic choke?
Old 02-24-2014, 08:42 AM
No, it's a manual choke Rasputin.
Old 02-24-2014, 10:20 AM
kenny nunez's Avatar
kenny nunez kenny nunez is offline
kenny nunez is starting off with a positive reputation.
Unhappy hard start
69er, Make sure that the "I" terminal on the solenoid is hot when in cranking mode and that the same voltage is present at the "BAT" side of the coil also.
It also may be caused by the aging of the wiring, it gets frail, just like us.
Old 02-24-2014, 10:35 AM
JEFFFAFA's Avatar
Well, I'm thinkin' if the fuel delivery system IS getting fuel to the carb then the carb must not be giving it to the engine. You said factory rebuilt. So I'm assuming you bought a rebuilt carb. We don't know why someone had originally taken this carb off their vehicle. You checked fuel (bowl) level and it was correct. So one of the carb's internal passages is holding fuel back when it's hot. The key here seems to be heat. I am also assuming the rebuilt carb came with a real thin gasket that will transmit engine heat to the carb. I would buy a thick carb gasket like the later model vehicles came with and try that. Ford part number was E5HZ9C477A.
Old 02-24-2014, 11:24 AM
cowboywanabe's Avatar
cowboywanabe cowboywanabe is offline
Posting Legend
cowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputation
Quote:
I've got a very similar issue with my truck... After it's somewhat warmed up, I can shut it down for 10 - 15 minutes and it will act up. Usually it fires up, then stalls. The first couple times it happened, I was sure it was the typical hot start/possible flooding issue. I held the pedal to the floor, but all it would do was crank away and would not catch. Finally got mad and pumped the pedal a few times and it fired right up. I still haven't figured out what exactly is going on, it seems like a fuel delivery issue of some sort.
Will keep an eye on this thread to see what you figure out.
2 bbl Motorcraft flooding 69'er 1967 - 1972 F-100 & Larger F-Series Trucks 7 01-25-2017 06:18 PM
Truck dying after warming up to temp Spencer Denton 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-25-2016 09:09 AM
1965 F-250 V8 won't start green47 1961 - 1966 F-100 & Larger F-Series Trucks 13 10-01-2016 07:41 AM
Fuel leaking out too carburetor Marcus80 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-11-2016 03:00 PM
272 Carb Flooding Issues Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-06-2015 07:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
