64 F250 4X4 120"WB - BEDS / THANKS FTE
First off, thanks to EricJ and 66stang for nearly immediate help with my post for a bed. FTE is awesome!! This one may be for the number guru: What is the deal with 1964 beds? I have seen photo after photo of 64 F250 4x4's with style side "long bed" and 1964 F100 4x4's with style side short beds. The style side I refer to has the nice "tear drop" wheel well and the body lines sure seem to match the cab. I've been told if I go with a short bed on my 120"WB, I would have to move the rear spring perches / whole she-bang 5" forward to create a 115" WB such as on the 65 / 66 model year? Are the "long bed" 64 250 4x4's I see moving the whole assembly aft?? Appreciate answers from anyone with facts!! Thanks!!
what do you want to do change wb or get a bed? wrong bed (57-60bed)is correct styleside bed for 4wd
http://i1257.photobucket.com/albums/...ps0b03a94d.jpg
you can use a flairside bed also
http://i1257.photobucket.com/albums/...ps3892bf94.jpg
same truck different beds 120" wb
These trucks are already oxcart type suspension, shorter WB?
1957/60 F100/350 Styleside beds installed on the following 1961/66's. Known as the "wrong beds" because the bed lines don't match the cab lines of these trucks:
1961/65 F100/250 4WD / 1961/66 F350 (9' Express only) / 1962/63 F100/250 2WD / 1966 F250 4WD
1964/66 F100/250 2WD & 1966 F100 4WD used different Styleside beds.
DO you have any pics of how you shortened the box? Thanks so much for this post.
I also used 1" blocks to line up the bed to cab,
This is the only pic I have...the primer shows where it was cut.
SocialDistortionFan
18
01-15-2021 09:22 PM
Little Wolf
03-23-2015 11:05 PM
