Just ordered a 1984 bronco ii fuel sending unit to modify. I sure hope it works. Does anyone know if the midship tank uses the standard sending unit? I need that one also.
Soooo....This is a temporary fix until I can possibly get another tank support. Anyone know of one that will fit? This narrow frame width is killing me.
I haven't looked for a replacement support. I work at a shop that has a large brake press. When I follow your write up on the bronco unit u and going too bring my support to work and bend a new one out of aluminum. I wouldn't think a fab shop in your area would charge alot to make you one. Just a thought. By the way nice work it's looking great
D7TZ-9275-B (replaced D0TZ-9275-D) .. Mid-Ship Fuel Tank Sending Unit / Obsolete
Finished all new wire harnesses from the cab back. Had time to lay it on the loose. I did connect the rear tank. I think it is an excellent substitute for the old tank. The old connector is too narrow so I did some engineering. Continuity checks are sat.
