aod to manual trans
Old 02-21-2014, 05:27 PM
hambone3531's Avatar
hambone3531
hambone3531 is offline
aod to manual trans
I have a 93 f150 4x4 regular cab long bed with the 5.0 and aod trans id like to convert to a manual trans cause my od has gone out and well i just love a stick was wondering what the conversion would take and how much trouble it would be
Old 02-21-2014, 06:47 PM
rikard's Avatar
rikard
rikard is offline
You will need the manual transmisson pedal assembly, a 5.0 flywheel, clutch master cylinder, shifter and boot, plus the transmission. You may have to change the cross member too.
Most 5 speed F150s of this era used the Mazda M5OD R2 while F250s got the ZF model. I have owned two trucks with the Mazda unit and had no issues in 200k plus miles.
Regards
rikard
Old 02-22-2014, 11:47 PM
hambone3531
Are their already holes in place for the pedel assembly and shifter i would imagine all the cabs had the provisions so that ford wouldnt have to have 2 different cab lines and also would their be wireing issues i know i would want to change the column as well
indigoman
02-06-2019 06:21 PM
OregonGuy1978
02-07-2010 10:22 PM
neon4x
05-06-2007 07:48 PM
shrike
07-15-2004 10:28 PM
Quick Reply: aod to manual trans
