aod to manual trans - Ford Truck Enthusiasts Forums
aod to manual trans
Old 02-21-2014, 06:27 PM
hambone3531 hambone3531 is offline
hambone3531 is starting off with a positive reputation.
aod to manual trans
I have a 93 f150 4x4 regular cab long bed with the 5.0 and aod trans id like to convert to a manual trans cause my od has gone out and well i just love a stick was wondering what the conversion would take and how much trouble it would be
Old 02-21-2014, 07:47 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
You will need the manual transmisson pedal assembly, a 5.0 flywheel, clutch master cylinder, shifter and boot, plus the transmission. You may have to change the cross member too.
Most 5 speed F150s of this era used the Mazda M5OD R2 while F250s got the ZF model. I have owned two trucks with the Mazda unit and had no issues in 200k plus miles.
Regards
rikard
Old 02-23-2014, 12:47 AM
Are their already holes in place for the pedel assembly and shifter i would imagine all the cabs had the provisions so that ford wouldnt have to have 2 different cab lines and also would their be wireing issues i know i would want to change the column as well
Best trans fluid for AOD 351Cleveland C4 1987 - 1996 F150 & Larger F-Series Trucks 9 06-01-2014 09:03 PM
94 e350 box truck AOD trans swap Gearheadman3 1968-2013 Full Size Vans 4 05-30-2014 04:31 PM
1976 F100 manual to AOD swap crossmember LuckyR 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-12-2014 06:09 PM
C4 to AOD swap A73F100 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-14-2014 08:50 PM
C4, C6, or AOD. Help me pick one Gbark 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-05-2013 09:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
