Does this sound like a rod or main bearing knock
The other day my engine started making knocking sound. It's louder when I first start the truck cold in the morning, then quietens down. It seems to occur mainly in gear and on acceleration between 900 - 1500 RPMS. I have pretty good oil pressure and the needle doesn't jump around at all. It's about 60 psi cold and after warming up at idle its around 27-30 and goes up to between 40-45 when actually driving. I took a quick video this morning driving through the parking lot at work. You may have to turn your speakers up, but you can hear it tap/knock when I accelerate about 6 secs into the video again at 20 secs and then again about 40 secs in the video. I revved the engine after putting it in park to show it's not really there at that time, I'm confused? It's like a hollow type knocking sound. Any insight would be great.
Edit: I use Rotella 10W-30 oil, and sometimes Rotella 15W-40. I did already pull the valve covers and check all the rocker arms and push rods and didn't see any issues with either. I ran it with the valve covers off to verify oil is circulating up through all the lifters and pushrods too.
Ok, here's a better video I took this morning. You can clearly hear the sound I'm talking about at about the 1 minute mark when I take off from the stop sign in front of the school.
302 knocking - YouTube
AYoungblood
10-28-2003 07:34 AM
