Squeaking Noise While applying Acceleration - Ford Truck Enthusiasts Forums
Old 02-21-2014, 08:44 AM
billest's Avatar
billest billest is offline
billest is starting off with a positive reputation.
Question Squeaking Noise While applying Acceleration
My truck is making a squeaking noise when i press the gas i do not know what it is, but it is very annoying. It stops sometimes when i press the gas but it keeps going after a little while maybe while im in 3rd gear it will stop, I took of the belt to the smog pump as i thought that was the problem anyone have the same problem but solved? Maybe i can get it taken care of tom. morning. HELP!
Old 02-21-2014, 08:45 AM
billest's Avatar
its a straight six 300
Old 02-21-2014, 12:04 PM
1986F150six 1986F150six is online now
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Check the tension of the remaining belts. Look at the underside of the belts and see if they are badly glazed. Do not overtighten them.
Does it seem to squeak [squeal] more when the air is humid? Does it make this noise immediately after starting the engine and then stop?
Old 02-21-2014, 02:28 PM
Brnfree's Avatar
Brnfree Brnfree is offline
Brnfree has a good reputation on FTE.Brnfree has a good reputation on FTE.
I had a fan clutch fail and it locked up. Caused belt squeal around 2700 RPM+.
Old 02-24-2014, 08:59 AM
billest's Avatar
it only happens sometimes but yes squealing is a better word
2009 Escape squeaking noise UNTIL tapping brakes Thunderknight Escape & Escape Hybrid 1 07-31-2015 10:25 PM
01 Ford Ranger Reverse Squeak and engine noise. Nicholas.Quirk Ranger & B-Series 4 10-14-2013 08:21 PM
Steering stabilizer squeaking Bowie 1999 - 2003 7.3L Power Stroke Diesel 3 08-27-2012 06:19 PM
Squeaks when in reverse... rbsample 1999 - 2003 7.3L Power Stroke Diesel 14 06-06-2011 10:21 PM
Squeak, squeak, squeak when turning left spdmpo 1999 - 2003 7.3L Power Stroke Diesel 13 05-28-2010 10:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
