heater shut off valve leaks
The heater shutoff valve on the intake manifold leaks on my 54. Would thread sealant like I used on my head bolts be what I should use to stop the leak? That would be better than Teflon tape, right?
It also leaks a little bit at the top of the valve. Can that be fixed with a washer or packing like a water spigot? Or should I buy a new one? I'd like to be able to find an original looking one, not a repro like this one.
Thanks.
Thanks.
Yup that is what I would do. In this spot I personally would use Lead Seal. As it's anti corrosion properties can't be beat and handles thermal changes better then most other thread sealants. What ever you use it will be better then nothing, do try to avoid Teflon tape.
Jet-Lube of Canada l No.60 - Lead Anti-Seize Compound
http://www.jetlubecanada.com/tds/No60.pdf
If you are stuck and in a pinch that is one thing, but to use it when you have access to or can get proper thread sealants is considered a hack job.
Leave the Teflon tape in the tool box and use it for what it was intended for, domestic plumbing, air lines and plastic pipe.
SVTDriver97
11-30-2015 07:20 AM
rost495
12-03-2004 04:36 PM
