Can I calibrate the fuel gauge?
I ran out of gas today, luckily I have a second tank, so i made it home, It sucked some crud in to the carb and would only run with the choke on.
Anyhow I took the sending unit out and checked the adjustment. the bottom line is the gauge won't read less than 1/4 tank with the key on. Key off it goes all the way down to empty. Can I add a "pull down resistor"
The good news is the tank looks to be in excellent condition, like new actually. Which is amazing considering it sat for 15 years.
Yes, you can add a resistor to bring it down. I would recommend an adjustable so you can control where you want it set. Something like this would work:
25-Ohm 3-Watt Rheostat - RadioShack.com
3 watts is overkill, but it will do the job & its cheap!
In series to the gage or across the sending unit resistor?
