StableLoad Upper Overload Part # A7200 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 02-20-2014, 05:37 PM
Bmcush Bmcush is offline
Bmcush is starting off with a positive reputation.
My new F250 has the camper package upper overloads. These uppers are for the F350 but I thinking they should work in my application.
Has anybody used these?
I'll have a 2500 lb cabover in the bed.
http://www.torklift.com/products/stableload.php
Old 02-20-2014, 11:25 PM
Gary2Fords Gary2Fords is offline
Gary2Fords is starting off with a positive reputation.
I have been using a similar product, SuperSway Stops, from Supersprings -http://www.supersprings.com/superswaystops_overview.asp - on my 2012 F250 FX4 Scab long bed. I installed them about a month into a three and a half month trip with our 1800 pound truck camper.
I was getting some sway when driving over uneven surfaces without them. Installing them helped quite a bit. This was my first experience with a truck camper so I donít have anything to compare to, but they do help keep the truck from rocking side to side.
If I have any complaint, it would be that there is a little spring slap when going over large bumps or dips. It isnít much and is almost nonexistent with a full water tank. I also have Firestone air bags installed and I donít know if that effects the performance of the SuperSway Stops. The problem is that when I air up the bags to level the truck, it raises the SuperSway Stops just slightly off of the overloads. All things considered, I would recommend this type of accessory.
I also have to say that the truck performed flawlessly for the whole ten thousand mile trip.
Old 02-21-2014, 01:24 AM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
My slide-in weighs around 3,000 lbs fully loaded. I looked at those upper overloads and couldn't justify the price versus what they are - just an extended rubber bump stop.
After I got my F-350 home the first thing I did was put the camper on to test how the truck would sit and ride and handle without any aftermarket load helper add-ons. The weight of the camper settled the suspension just barely so the overloads were touching the factory stops, and the truck sat level. Handling was about the same as what I was used to with the older F-250 with AirLift old bags.
A thousand or so miles later I added a set of the stabil-loads, those funky little things that bolt onto the ends of the lower leaf springs. I didn't stack them as I wanted them far away from the springs while unloaded. The truck doesn't sit any higher, that's OK as it is still level, but there was a noticeable improvement in handling.
I think the lower stabil-loads are a far better choice than those upper bump stops.
By the way, I also purchased a set of AirLift springs but after 4,000 miles of hauling the camper I just don't see a need for them, and I probably won't install them.
-Joe
Old 02-21-2014, 08:07 PM
Yeah the more I think about it the more I think these upper units are more for sway control than weight bearing. I'm sure my 250 will need something to get it back level with the camper.
Thanks Guys
Old 02-24-2014, 08:03 AM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
This is what I added to my truck http://www.supersprings.com/Application_Flyers/SSA16_Ford_F-350_SD_(2011~)rev_1012.jpg
And here are some picks, the instructions were off for mine but it still works. My truck sat a little low with a cap and tools so this spring brought the back end up 1.5"s or so and settles perfect when hitched up to my TT, about 900# tongue weight and I load about another 500 to 800 # of wood and other camping stuff in bed. It does ride stiffer unloaded but I left them in for the winter and its been fine on snow and ice without skipping around.
http://i729.photobucket.com/albums/w...184125_322.jpg
http://i729.photobucket.com/albums/w...184002_192.jpg
The shackle has not hit the overload stopper even though it looks close, I have had 2k# of wood pellets in the back and went over some bad RR Tracks a couple times this winter and never felt it bottem out or hit anything.
I did add a hose over the brake cable to prevent rubbing after the pics. The instructions show the cable in a different location.
Old 03-08-2014, 11:39 PM
RZAR's Avatar
RZAR RZAR is offline
RZAR is gaining momentum as a positive member of FTE.
I added the upper stable loads to my truck and it really helped with the sway when I am hauling my Lance Camper. My truck sat level without them but the sway was a little to much for me on windy days. My truck also has the camper package and Rancho 9000's and that's it. My only complaint is that the overloads slap the stable loads over bumps when the truck is empty. I trimmed the stable loads a little and got rid of most of the slapping. When I first installed the Stable Loads I was surprised to see how close they were to the overload leafs when the truck was empty.
StableLoad -- The Weight Off Your Shoulders Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 1 06-02-2016 08:48 PM
Go on an epic roadtrip with your Torklift StableLoads Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 09-22-2015 06:02 PM
How does truck sag affect my vehicle? Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 04-15-2015 12:11 PM
Finding the best suspension options for your vehicle Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-16-2015 04:08 PM
My new Ford F150 shudders and I donít know why Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-12-2015 01:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
