Bring auto window back up with out power.
on
I just got a non-running 91 F250 and before the truck was parked and torn into the passenger window was rolled down. I need to get it back up so it doesn't ruin the interior but the truck is in pieces and can't hook power up to it. How can I get the window up without rolling it up with the motor? Am I going to have to tie it up after disconnecting it from the motor? I just need it up so I don't have the interior trashed.
Trav
Trav
Pulled the door panel and then accessed the window motor. Pulled the motor out and open the motor to check for any mashed teeth. No mashed or missing teeth reconnect4ed the motor prior to reinstall and it worked fine. Couldn't find anything out of place, so I think it maybe it was just been jammed for some unknown reason. Happy that was all it was. You get lucky once in a while. Thanks for your good
comments on the fix. As always, this forum rocks!!!
Methodical_1
1997-2006 Expedition & Navigator
18
06-12-2018 08:50 AM
shotgunner426
10-03-2003 04:06 PM
