Tech: Budget 302/351 Serpentine Drive - Ford Truck Enthusiasts Forums
Old 02-19-2014, 11:22 PM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
Since I've been lately playing around with my engine accessories, I figured I could do a little write up on serpentine pulleys used on 302 and 351 engines. Some of us don't want to spend the $$$ on billet stuff.
Thank goodness Ford standardized their serpentine pulleys for the most part. Pretty much everyone knows that the factory V belt setups are a complete mess if your going to mix and match.
I'm going to concentrate mostly on the 1979-93 Mustang and 1987-96 F-Series/E-Series because they have automatic tensioners and you can mix and match them. There are some Cougars and Mark VII that also share the Mustang setup. The Crown Vic, Grand Marquis and Continental is sort of an odd ball setup with dual belts and manual adjustment.
I'll start with pulleys first. This isn't a complete list of all the pulleys offered. Ford liked to update part numbers even though the pulley is the same. These are most likely what your going to come across.
Alternators
Left: 1979-93 Mustang 2G Alt– D9ZF-10A352-AA – 2 1/8”
Right: 90's F-150 3G Alt – F0VU-A2A – 2 1/2”
The 2G and 3G alternator pulleys aren't interchangeable. There are a whole bunch of various sizes of pulleys out there to choose from.
Water pump
Left: 1989-96 F/E-Series – E9TA-8A528-AA – 5”
Middle: 1987-88 F/E-Series – E7SE-8A528-BA – 5”
Right: 1979-93 Mustang – E1ZE-8509-AA – 4.75”
These require a reverse rotation water pump. The bolt pattern is different from a standard rotation pump. The 1979-93 Mustangs used a standard rotation timing cover while the 87-96 trucks/van got a proper reverse rotation timing cover. Typically replacement Mustang water pumps just have a round whole on the back plate so they can bolt to either style timing cover. Truck/Van pumps do not. Crown Vic/Grand Marquis/Continental have a ribbed pulley for standard rotation water pumps.
Crankshaft
Left: 1979-93 Mustang – E4ZE-6312-A7A – 6 1/8”
Right: 1987-96 F/E-Series – F2UA-6312-CA – 6 3/4”
This is where you have to watch out for. Ford started using a 4 bolt harmonic dampner in 1970 and have made them in different thicknesses over the years. You may require a spacer on your harmonic dampner depending on what year it is.
Power Steering
Left: 1987-96 E-Series Saginaw pump – E7UA-3D673-FB – 5 7/8” - Steel
Right: 1979-93 Mustang Ford pump – D9ZC-3D673A-A7A – 5 3/8” - Steel
Top: 1987-96 F-Series Ford pump - E57C-3D673-BA – 5 3/4” - Plastic
Bottom: 1987-96 F/E-Series 300 I6 Ford pump - E8TA-3D673-AA – 5 3/8” - Steel
This is pretty simple. Ford pumps require a Ford pump pulley. There are a bunch out there since the pump didn't change much between 1978-2007. Don't really know why they used a plastic pulley on the trucks and cars (except mustang). The E-Series Saginaw pumps require the Saginaw pulley as the center hole is bigger.
Air Pump
Top: 1979-93 Mustang – E4ZE-9C480-A7A – 4 3/4”
Middle: Cars/1987-96 F/E-Series 300 I6 – E5AE-9C480-AA – 5 1/8”
Bottom: 1987-96 F/E-Series – E7TA-9C480-BA – 5 3/4”
I'm including these pulleys for those that might be required to have them or those going to run a vacuum pump and don't want spend money on a billet pulley.
Tensioners
Left: 1979-84 Mustang
Right: 1985-93 Mustang/1987-92 F/E-Series
Not shown: 1993-96 F/E-Series
The newer style tensioners will fit the older Mustangs but will require a nut for the bolt. Cars used a 76mm pulley and the trucks used a 90mm pulley. Otherwise they are identical. The 1993+ truck tensioner is its own design.
Accessory Brackets
Passenger side – Alternator and Air pump
1979-84 Mustang
1993-96 F/E-Series
Both styles of the Mustang brackets are essentially the same. The 1985 and up brackets just added a threaded boss for the tensioner and sliding metal sleeves on the accessory holes to account for any slack. The 1993+ changed the alternator mount to a three bolt and tensioner. It also requires an idler pulley if the air pump is removed. The older style is much better looking. All mounting brackets bolt directly to the head so they work for a 302 and 351W.
Drivers side – Power steering/Power steering and Air conditioning
1979-84 Mustang – Power Steering
1979-84 Mustang – Power Steering and Air conditioning
1985-93 Mustang – Power Steering
1985-93 Mustang – Power Steering and Air conditioning
1987 F-Series - Power Steering and Air conditioning
1987 E-Series - Power Steering and Air conditioning
1988-96 F-Series – Power Steering and Air conditioning
1988-96 E-Series – Power Steering and Air conditioning
The Mustang brackets WILL NOT work on a 351W as they have separate brackets that bolt to the head and water pump. The truck and van brackets are designed to bolt to both engines. Its probably best to stick with the truck/van brackets as they are self contained. The Mustang ones have several pieces and get confusing if it has factory or dealer installed air conditioning.
Here is my engine mocked up with 1984 Mustang brackets:
Here is my engine mocked up with the 1988+ E-Series passenger bracket: (F-Series similar)
Hopefully this might help someone out.
Old 02-20-2014, 12:14 AM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
Looks like very useful info. Any chance you would have similar info for big blocks?
Old 02-20-2014, 09:04 AM
51dueller's Avatar
The 460 uses a two belt system. One side is manual tension and the other has the automatic tensioner. 460 EFI heads are different than carbed ones so they could have also changed the mounting holes on the brackets. I haven't really seen or messed with them at all.
Old 02-23-2014, 07:13 PM
51dueller's Avatar
Turns out there is a 1987 302 truck only bracket that is designed for the older style A/C compressor.
I have the factory A/C bypass pulley for this one. Dorman makes a new bypass pulley for the 1988+ brackets.
I also updated the first post with a picture of the other power steering pulleys.
Old 02-23-2014, 07:24 PM
ryans88gt's Avatar
ryans88gt ryans88gt is offline
ryans88gt is gaining momentum as a positive member of FTE.ryans88gt is gaining momentum as a positive member of FTE.
awesome info.
I was going to use the factory style ford brackets, but opted for this set I purchased on ebay for $90 including hardware for both.
Required a little modification, but I like the look.
Old 12-30-2014, 07:37 PM
OK F1's Avatar
OK F1 OK F1 is offline
OK F1 is gaining momentum as a positive member of FTE.OK F1 is gaining momentum as a positive member of FTE.
Nice write-up...reps
Old 12-30-2014, 09:08 PM
cruiser456's Avatar
cruiser456 cruiser456 is offline
cruiser456 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ryans88gt View Post
awesome info.
I was looking at this setup as well.What modifications did you have to do?
Thanks
Old 12-30-2014, 09:59 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Great thread. Thanks for the info.
Old 12-30-2014, 10:02 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
awesome info.
Have you actually run this engine with this belt setup? I would be a little leary about the water pump pulley...not much belt making contact with the pulley and the ribs are on the wrong side for this routing unless that waater pump pulley is smooth which will really exacerbate the friction issue.
Frameswap 3.0: The Reckoning 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 47 02-16-2016 07:54 PM
Can you spot the difference? 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-19-2014 07:17 PM
Rear disc brake tech for F-2/3 or F-250/350 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-17-2013 10:10 PM
Battery Box Source 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-08-2010 10:35 PM
Homemade Tools 51dueller Manitoba / Saskatchewan Chapter 12 10-26-2009 02:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
