1996 F250 5.8 fuel pressure issue - Ford Truck Enthusiasts Forums
Old 02-19-2014, 06:33 PM
digicon digicon is offline
digicon is starting off with a positive reputation.
Guys,
I have a 96 F250 4WD 5.8 that I have just owned for about a month. The truck had 130,000 miles on it and has been very well maintained and cared for by the previous owner. However the truck idles and runs fine but has no WOT power. Up until now I had only ran off of the Front fuel tank I suspected a fuel problem so filled the back tank and it was noticeably better.
Just so I wasn't imagining things, I bought a fuel pressure gauge and this is what I found.
Front Tank: (No Power at WOT)
1) 33psi running.
2) At Wide open Throttle fuel pressure goes to 23psi
3) I can cycle switch 3 times to a max of 23psi.
4) Pressure bleeds back over the course of a few minutes to 0psi
5) Fuel pressure acts no different if vacuum is connected or not to FPR.
Rear Tank: (Noticeably More Power at WOT)
1) 43psi running.
2) At Wide open Throttle fuel pressure goes to 33psi
3) I can cycle switch 3 times to a max of 33psi.
It appears my front pump is weak. Should they both DECREASE fuel pressure when given a WOT cycle? Any input would be greatly appreciated.
Thanks,
Mike
Old 02-19-2014, 06:55 PM
One other thing. I momentarily had the CEL come on last week. I read the code and it was a 172 (lean condition). The light came on for a while then was gone. All of this while running on the front tank. Keep in mind, I have only ran 3 tanks of fuel through this truck since I have owned it in 2 months. All through the front tank.
Old 02-19-2014, 06:57 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by digicon View Post
Guys,
1) 33psi running.
1) 43psi running.
Thanks,
Mike
The lower the vacuum signal is the HIGER the fuel pressure should be. Lower vacuum equals more throttle/load therefore more fuel is required.
BTW....43 PSI at idle is way too high.......
Old 02-19-2014, 07:09 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
There should not be a drop in fuel pressure at WOT, in this case it should increase from 32-35psi at idle to the 40-45psi range under load. Is the vacuum line attached to the pressure regulator? It should be. Fuel pressure should not bleed off any visible amount over a short period of time either so you have 2 problems.. weak pump in the front tank and a possible fuel transfer problem(pressure bleeding off to the other tank) or leaking injectors.
Old 02-19-2014, 07:16 PM
It is attached. And both tank pressures decrease under WOT about 10psi accordingly. I don't see any difference when idling, as it pertains to fuel pressure, whether the FPR vacuum line is connected or not.......and there is definitely vacuum at the line. I can feel it.
Old 02-19-2014, 07:24 PM
rla2005's Avatar
Start by replacing the fuel pressure regulator/
Old 02-21-2014, 07:09 PM
thewestie thewestie is offline
thewestie is starting off with a positive reputation.
digicon how are you making out. I'm chasing a similar problem?
Old 02-21-2014, 09:34 PM
I went out tonight and put a gauge on it again. Pressure from both tank (though different PSI reading) act exactly the same. Both decrease with throttle and bleed off after shut down. And act no differently weather the vacuum is supplied or not.
So....I took the FPR off. Beat it around, applied some vacuum, cleaned it off etc. Reinstalled and for once it held pressure after shutting of the truck. At least that was different. It still decreased pressure upon throttle but I did change one aspect of it.
So....I am thinking it is bad. I plan on replacing it this week. Possibly tomorrow. I'll post the findings.
What are your symptoms?
Mike
Old 02-22-2014, 12:27 AM
Similar as yours codes are 172 and ocasonaly 173. I put a gauge on it and had 30 psi running and 40 off. no change when disconnect of vac and it would jump and settle down on throttle. I started to poor out so I went in. Ill get back at in the am
Old 02-22-2014, 07:40 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
If you have "30 psi running and 40 off" then the FPR is working and the vacuum is dropping it to 30 psi at idle.
Old 02-22-2014, 08:58 AM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Haven't seen it mentioned, but has the fuel filter been changed? I had a similar problem, and just changing the filter made a big difference.
Old 02-22-2014, 03:26 PM
For what it is worth. I just replaced the FPR and hooked up the gauges. Every problem is fixed. Fuel at idle settles at 30psi from both tanks now. Fuel pressure INCREASES upon throttle from both tanks and best of all fuel pressure does not bleed.....actually bumps up about 2 psi upon shut off and holds steady.
All I did was replace the fuel pressure regulator.
Hope this helps you guys
Mike
Old 02-22-2014, 03:30 PM
Timbersteel, Good Point I should have mentioned. The first thing I did was crawl under the truck and noticed it had a brand new fuel filter. Actually the people I bought it from just replaced fuel filter, plugs, rotor, cap, wires, etc. Probably trying to fix this problem. $40.00 later.....I think it is fixed
97 F150 4.6l starting issue Penton97F150 1997 - 2003 F150 8 06-26-2016 10:49 PM
Fuel Pressure Help failsatheals 1997 - 2003 F150 5 06-21-2016 09:03 PM
Installed fuel pressure gauge evan1242 6.0L Power Stroke Diesel 13 07-14-2015 05:24 AM
Adjustable FPR on a 460? Need advice 390Highboy 1987 - 1996 F150 & Larger F-Series Trucks 2 01-01-2014 07:53 PM
Fuel pressure question? jemini Fuel Injection, Carburetion & Fuel System 3 05-02-2008 07:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
