Tapered Brake pads
Tapered Brake pads
I'm having an issue with my outer brake pads being tapered to where there is at least 1/6 more pad at the top than the bottom. i have had this issue with the old calipers and as well with the new calipers and pads. I have cleaned the pin slide groves with a wire wheel on my Dremel. And used Brake hardware grease on the slides and still i have the problem.
What else should i check or do????
