2wd vs 4x4 ride height - Ford Truck Enthusiasts Forums
Old 02-19-2014, 10:50 AM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
I've never seen an actual answer to this, just speculation, but can anyone tell me how much higher a 4x4 truck sits over a 2wd truck in stock form. This is on f150 with stock coil springs.
Old 02-19-2014, 10:52 AM
Evan_P's Avatar
Evan_P Evan_P is online now
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
I think it's between 1-2", but I could be wrong.
Old 02-19-2014, 11:07 AM
Jarryd's Avatar
I ask because I'll be buying all the parts soon and I don't know if I want to spend the money on a lift yet. If I can get 2 inches out of the conversion alone, I can reuse my leveling kit and be 4" taller than when my truck was new and I'll be pretty content with that for a while. If its not that much, I may go on and save more so I can invest in a lift kit and just go big all at once.
Old 02-20-2014, 07:03 PM
stydel311's Avatar
stydel311 stydel311 is offline
stydel311 is starting off with a positive reputation.
Pretty sure the front end just sits higher by about an 2 or 3 inches on a 4x4 because the axle is underneath it.
Old 02-21-2014, 09:02 AM
blue924.9's Avatar
blue924.9 blue924.9 is offline
blue924.9 is starting off with a positive reputation.
1-2 inches on the front only
Old 02-21-2014, 09:12 AM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
Quote:
I'd do the conversion with the leveling kit and see. I drove around with 32" tires and stock 4x4 height for a long time. I had one person ask me if I installed my lift kit myself
This also will give you a chance to see how you like the handling of the truck with the higher center of gravity. If you still want more after that, go for it.
I did level my truck last July, and I don't see myself making the truck any taller any time soon.
Old 02-26-2014, 04:01 PM
IsaacCarlson IsaacCarlson is offline
IsaacCarlson is starting off with a positive reputation.
My 2wd sits pretty high with 32's on it. You have to put a little effort into getting up into the seat.
Old 02-26-2014, 04:50 PM
Jarryd's Avatar
Quote:
I have 33s already.
1997 F150 4x4,1999 tranny 2wd conversion ? Realslowww 1997 - 2003 F150 9 11-29-2016 06:27 PM
95 F150 2WD conversion to 4x4 (4WD) MusicBro 1987 - 1996 F150 & Larger F-Series Trucks 12 07-19-2015 07:55 PM
Is there a difference between 2wd and 4wd pitman arms? 85Supclub 1987 - 1996 F150 & Larger F-Series Trucks 5 04-20-2015 09:40 AM
4X4 Trans pan on 4X2 - Any Ground Clearance-Related Issues? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 7 04-24-2014 09:33 PM
Lets see those 2wd TheTitanNAHS 1973 - 1979 F-100 & Larger F-Series Trucks 18 12-12-2013 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
