Still confused....lope/romp ? need help Thanks
Ok yes, I know there's tons of info about this but I'm evidently not processing it properly (I'm old ). My 97 psd is only romping/loping when I start in neutral, not in park. That means its not the range sensor (I think). What would it be then?
Thanks, Vinny
Thanks, Vinny
Actually, it probably is the range sensor, only it's the Neutral position that's failing rather than the Park position. The sensor/switch works like the HVAC fan speed, a "stepped" series of resistors; as you move the shifter, the resistance across the two terminals to the sensor goes up and down (one resistor in series at a time). It could be that for some reason, in Neutral, it's not sending the right resistance value to the PCM. Or it could just be out of adjustment in some way that it works in Park and the driving gears, but not in Neutral. Might be interesting to start it in Neutral, and while it's romping, gently move the shifter toward Reverse and toward Drive, see if at some point the romp goes away. Just a WAG.
DiesalBoyz2000
12-24-2010 10:58 AM
jscarb2
02-15-2006 03:21 PM
