64 top loader, three on the tree in a 62 4x4?
Hi, I'm trying to fix my 62 f100 and I found a guy with a 3 speed transmission from a 64 f100 that bolts on apparently just like mine. I was wondering if anyone could help me narrow down what I have and what will work as a replacement. Mine won't currently go in first gear, it will go into first gear but will "pop out" of first if I let the clutch out. I want to rebuild mine as a spare and run this other 64 transmission for now. Any help is appreciated and here are some pictures of my transmission.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Ford type 3.03 3 speed manual all syncromesh transmission introduced in 1963 F100/250, Galaxie & Fairlane/Meteor/Falcon/Comet w/V8's. Used thru 1986 in a gazillion different vehicles.
1962 and earlier Borg Warner T-86 3 speed manual does not have a syncromesh 1st gear.
The output shaft and extension housings of passenger cars are different lengths than trucks. Have a flange on the housing that the trans mount bolts to.
The bell housings used on 1961/64 F100/250 2WD/4WD, 1961/66 F350, 1965 F100/250 4WD, 1966 F250 4WD have 2 'ears' that the rear motor mounts attach to.
Swapping in a 3.03 into a 1962, the trans may/may not bolt to the bell housing, the driveshaft may be a different length.
hayman68
06-25-2014 11:29 PM
Pickupmanx2
02-11-2013 12:09 PM
