Bullydog Propane Tank - Ford Truck Enthusiasts Forums
Old 02-18-2014, 04:45 PM
jonnybronco jonnybronco is offline
jonnybronco is new and has a neutral reputation at this point.
Can a Bullydog Propane tank be used as a fuel tank for a propane conversion? I am assuming it uses a liquid line like is needed for running a gas engine on propane?
I am trying to find a used tank and want to know if the Bullydog tanks are a viable option for my propane converted Bronco.
Thanks
Jonny
Old 03-04-2014, 10:08 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Um, not sure if your engine was a gasoline one or diesel. If gasoline, put this in another forum.
As far as I can tell, you want to run vapor.
Thing is, unlike running a gasoline engine, you're only adding a /little/ propane to your diesel. Add too much and you get pinging, so you have to keep the ratio low.
If you've got a vapor valve(the fill valve might work?), that's best.
Alternately, if you find one, a small vaporizer unit like they use on a forklift/car would do the trick.
P.S, two things:
1. It's possible to make an IDI /run/ entirely on propane vapor... though very poorly, due to no timing control(it burns when you manage to get a good ratio and heat).
2. You need to have enough air to burn the propane; you'll only get extra power out of the propane if you've got a lean burn already. This means a turbo, or bigger turbo.
Old 03-07-2014, 12:27 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
best to use a boost switch to active the propane only when needed, and when the engine will benefit, at load, and it will cut out when boost drops, cruse.
propane conversion. TaborCT 1967 - 1972 F-100 & Larger F-Series Trucks 15 09-03-2011 08:04 AM
Propane Tank as an Air Tank? Bruker Garage & Workshop 14 02-03-2009 04:49 PM
Propane conversion- 95 F250 superduty4x4 1987 - 1996 F150 & Larger F-Series Trucks 3 04-19-2006 08:36 PM
Propane bassproguy07 Bio-diesel, Propane & Alternative Diesel Engine Fuels 6 02-26-2006 03:20 PM
bullydog propane injection...good or bad? burly1 Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 03-03-2003 06:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
