Offroad & 4x4
Hydroboost brake in place of stock.
Old 02-18-2014, 02:02 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Is the Hydroboost system better than stock?
I have my 96 Bronco I am working on (starting to work on again) and I noticed that I may have a small leak at the
rear of the master cylinder. I know that the Hydroboost system is pricey, but will it be worth the effort to install.
I plan to install larger tires in the future - maybe 37s.
Does the Hydroboost replace the stock booster?
Old 02-18-2014, 02:33 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,106 Likes on 2,167 Posts
yes yes and yes.
unbolt everything and bolt the hydroboost in.
i am pretty sure you need to use the brake pedal pushrod off the hydroboost system too
hydroboost is a much better system than the vacuum booster.
roostercrows
06-17-2019 07:16 AM
Broncobobby76
10-17-2013 07:10 AM
gotta56
08-01-2006 03:56 AM
92CajunExpress
11-12-2005 04:50 PM
57 chevy
07-28-2003 08:26 AM
Quick Reply: Hydroboost brake in place of stock.
