whats the difference between dextron 2 and dextron 3 atf??? - Ford Truck Enthusiasts Forums
Old 06-30-2003, 10:18 AM
gingerbreadmaniac gingerbreadmaniac is offline
gingerbreadmaniac is starting off with a positive reputation.
The transfer case in my 85 f150 calls for dextron2 a.t.f, its a little low so i went to wall mart (the only place open last night) and all they had was dextron3.........
whats the difference between dextron 2 and dextron 3 a.t.f?????
ill go to the auto store today and get some dextron2 but would dextron 3 work just aswell?????
-gbm-
Old 06-30-2003, 10:47 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
Dexron III replaced Dexron II and meets or exceeds the same performance specifications.
Trans fluid GeneGregory 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-27-2016 06:21 PM
Power Steering Pump Refill - Type F ATF or ESW-M2C128-B PS Fluid JH1975 1973 - 1979 F-100 & Larger F-Series Trucks 19 08-27-2015 10:59 PM
Rebuilt C6 Transmission: Use Type F or Dextron? ajbremer 1967 - 1972 F-100 & Larger F-Series Trucks 8 03-21-2015 07:39 PM
Mercon II or III? Stokes Oil & Lubrication 8 05-16-2013 05:49 AM
put wrong fluid in power steering: dextron instead of type F rb76543 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 05-29-2010 11:33 PM
Tags
atf, case, dexron, dextron, difference, differnece, ford, ii, iii, performance, required, requiring, transfer, update, whats, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
