Starting my Coe build starting right is half the battle - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-23-2014, 10:40 PM
pweng1's Avatar
pweng1 pweng1 is offline
pweng1 has a good reputation on FTE.pweng1 has a good reputation on FTE.
Rust removal
After reading a ton of rust removal opinions I decided to start 2 15 gal drums one has molasses the other muraic acid . I might as well start cleaning up the parts and brackets. I will put the sandblaster to work later in the spring
  #32
Old 02-26-2014, 02:39 PM
vintage56's Avatar
vintage56 vintage56 is offline
vintage56 is starting off with a positive reputation.
One of the tall hurdles on any coe project is steering. I'd advise a plan there too.
JML
  #33
Old 02-26-2014, 07:49 PM
pweng1's Avatar
Thanks My donor chasis is the 91 250 4 wd. When it was rolled in the snow it broke the steering box shaft. When i went to the junk yard i found out that the same steering box fits many years and vans too. I was curious how so i was shown a differant pitman arm for vans and told the same may sit on on frame differantly for angle but the pitman arm change will make the front end right. Do you think this is correct?
  #34
Old 02-26-2014, 09:53 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Where is the steering box located on the frame? Is it forward of the front axle center line? If behind the axle it will never work.
I used to have an '89 Ford 4x4, but don't remember how the steering was set up...
  #35
Old 02-27-2014, 12:16 AM
pweng1's Avatar
steering
It is about even with the rim edge fwd of the wheel 6 " aft of the headlight wrap around
  #36
Old 03-03-2014, 12:10 AM
pweng1's Avatar
some bad metal
Size:  172.0 KBWell after looking at some of my sheet metal i really think i will need to sharpen my fab skills. I will be doing lots of replacement.
  #37
Old 03-03-2014, 09:21 AM
tinman52's Avatar
Welder User
Ouch, that's pretty bad....
Maybe you could splice in some pieces from some better doors? Regular truck doors are the same except for the front corners.....
  #38
Old 03-03-2014, 12:18 PM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Now these trucks are awsome, maybe next project...... Sometime
  #39
Old 03-03-2014, 12:42 PM
pweng1's Avatar
No fender cut out
Tin man that is a reg cab door its to the back cab i have some spare i hope they are all better than this one
  #40
Old 03-03-2014, 02:49 PM
tinman52's Avatar
Welder User
Quote:
Gotcha. I have some extra doors too if you need some patch panels. Just ask....
I kinda wish I had gone ahead with the crew cab on mine......
Maybe the next one?
  #41
Old 03-03-2014, 08:53 PM
vintage56's Avatar
The explanation on steering sounds good.
Trust but verify.
Bottom line, the steering input shaft wants to be inclined upward like a van, not rearward like a conventional cab truck.
  #42
Old 03-05-2014, 10:02 PM
pweng1's Avatar
steering box pic
Well got a pic of how far fwd the steering box is on 4wds I think it is far enough fwd to work. If i change the angle like a van bolts on ill use a van pitman arm if i leave it as it is i can keep the existing. This is not my year frame and mine is more boxed fwd so i can change angle. Im glad im planning these things now so it murphy and his law dont bite me later.
  #43
Old 03-05-2014, 10:12 PM
pweng1's Avatar
Maybe the next one?
Thanks tinman i will see how bad the others are and let you know. I have limited space so im holding down on parts till spring. I still have to make room for the other cab and frame of the 51 im not building
  #44
Old 03-06-2014, 12:49 PM
pweng1's Avatar
Brake system
Ok guys if i am correct this is the unit i should put on my 54 coe Its a hydro boost What else do i need to buy or rig
  #45
Old 03-13-2014, 06:06 PM
pweng1's Avatar
Murphys law kicking my ***
Been overseas not able to work on much. I had setback when went to get my Cabs that were in good shape roof and back but seller took them off frame dented the hell out of them. Dragging them up hill. Pics will come when I am able to upload
Wait to start light goes on for only half a second in morning when cold. Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 09-29-2015 01:01 PM
Starting Issues perryg114 Modular V10 (6.8l) 8 02-01-2015 10:01 AM
F 250 extended cab rear half doors bobbyray1963 1999 to 2016 Super Duty 2 09-21-2014 12:04 PM
front half shaft swap 99 in a 03 expedition03EB Expedition & Navigator 0 07-22-2014 08:24 PM
2000 just dies when stopping Ksauers 1997 - 2003 F150 6 05-28-2014 02:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
