Possible throwout bearing issues?
My 78 f250 4x4 with a 460 mounted to a 4spd from my old 351m and I'm hearing some crazy noises underneath the truck when the clutch is engaged. It sounds like a grinding noise but I don't know how else to describe it. My dad says it's the throwout bearing but I would just like some more input before I decide to pull the transfer case and transmission
I too have the same problem, on my 78 f100 w/302 4sp Granny first. I hear it when the clutch pedal is depressed and in 1st gear when clutch is out ? Was planning on replacing throwout bearing and bushing, how hard is this to do ? And should I replace clutch at same time even if it's good since I have it apart ?
When the pedal is depressed, sorry I should have specified. Mine is having the same issue as yours Underthoaks. I'm not gonna change my clutch because I just replaced it when I did my swap which was only like 2 years ago. The clutch still works fine and seems fine but if I take it apart and I find a problem then I will replace it
diesel85
12-03-2015 10:01 AM
skuteman
03-19-2005 07:12 AM
