Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
04 escape airbag code 37?
Old 02-17-2014, 07:56 PM
rcgtsport's Avatar
rcgtsport
rcgtsport is offline
hey guys, girlfriends 04 escape airbag light is blinking code 37. read something about it being on passenger side what do i look for ? just got done putting in 2 coils,2 cats, egr,o2 senser,intake gaskets upper and lower,pcv,injector orings all due to misfire sure there not connected just added info. other problems include heated seat switch lights for a second then shuts off, and no cruize control. need to get light off for inspection by end of month any help would be great!
Old 02-19-2014, 10:23 PM
FireMe's Avatar
FireMe
FireMe is offline
Lamp fault code 37 indicates a circuit fault in the passenger side airbag circuits. You will need to pull codes from the RCM, as the lamp code is generic and won't point you in a meaningful direction. In the mean time, you can disconnect the battery then disconnect and inspect the airbag connectors under the passenger seat. They are yellow, so easy to spot. Sometimes there is just a bad connection in the connectors and disconnecting and reconnecting them can fix the problem.
Old 02-20-2014, 07:54 PM
rcgtsport's Avatar
rcgtsport
ok thanks i disconnected plug under seat spray them with electic cleaner and reconnected them. so far see hasnt said it came back on. looking at code reader - scaner.
esten07
2004 - 2008 F150
12-12-2015 07:42 AM
JJ76014
05-17-2014 07:56 PM
chudoc
1999 to 2016 Super Duty
06-21-2010 02:46 PM
tjc transport
03-26-2009 05:42 PM
m1abrams
04-19-2003 08:43 PM
Quick Reply: 04 escape airbag code 37?
