throttle
Old 02-17-2014, 06:42 PM
johnglock45's Avatar
johnglock45
johnglock45 is offline
throttle
Anyone know where I can get factory(stock) throttle linkage for 1950 f1??? Need from pedal to carb--mine has flathead 8--Im in oho,thanks
Old 02-17-2014, 07:28 PM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
Have you posted in this site's wanted section? Jag
Old 02-17-2014, 07:35 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
There's one on eBay for $25: http://www.ebay.com/itm/like/331061649884?lpid=82
DW
Old 02-18-2014, 07:06 PM
johnglock45
throttle
Have not went to parts wanted yet,looked at the add for the 50 throttle linkage and his add said came off 50 woody ,it has the 2 bolt bracket to the firewall==mine has 1 hole each side pedestal type,found another in the add,but has been welded on==will keep looking--mine totally missing.I think the linkage to the pedal is part of the bracket and a separate rod goes to the carb.?
Old 02-18-2014, 08:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The eBay item is a car piece. There's a 6-cyl truck piece for 48-51's on eBay that could be re-worked, but I'm sure someone will have the right piece. It is all one piece of rod bent at both ends, with a center tube crimped over it that the pedestals fit onto.
Old 02-18-2014, 08:27 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
Is a 51 the same? I'm in Ohio and I have a 51 f5 with a v8, but I do not know the 48-52 trucks what fits and what doesnt
Old 02-18-2014, 09:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As long as it's a V8, it will fit. Only the 6's are different, and 48-51 is different than 52 in the 6's.
Old 02-19-2014, 06:44 PM
johnglock45
Throttle
Kevin, I live in ohio not (OHO) AS I POSTED but im sure you knew that, anyhow I need all of the throttle linkage,from the pedal to the carb if you have it.Sounds like it will fit from what someone else posted,let me know what you have and how much. thanks, John----I live around the Dayton area--cell 937 313-1694
Old 07-19-2014, 09:12 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
Hey John, I have a factory linkage off y 1950 F3 and it had a 239. Let me know if you still need it. Randy
Spparky82
08-18-2015 08:40 AM
tip49
07-17-2007 01:22 PM
77dream
07-30-2003 08:54 AM
Sedric
08-31-2002 05:49 AM
Quick Reply: throttle
