Turbo Boost? - Ford Truck Enthusiasts Forums
Turbo Boost?
Old 02-17-2014, 05:51 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Turbo Boost?
My 93 diesel has a Banks turbocharger in it. I am running 100% bio diesel. When I am running 60MPH (2000RPM) my EGT is 350F and my boost is 3PSI. My question is, can I increase boost by wrapping the intake pipe with thermal blanket to increase heat to turbo? I will not by-pass the limiter that prevents max 10PSI boost. If I push down on the accelerater thereby dumping more fuel into chamber hence higher EGT, the boost increases. Anyone else have any suggestions other than that? Do they make blankets for that purpose and is it a great help?
Thanks for your input
Tom
Old 02-17-2014, 06:01 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
to get more boost you meed to make the engine work harder.
if i am rolling down a flat road at 60 mph cruising with no load i will only see 1-2 lbs boost.
if i am standing on it, 3100rpm towing 20,000 lbs up a 17% grade, i will see 15+ lbs boost.
Old 02-17-2014, 08:54 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Yup; boost = fuel burnt.
350F sounds low, though, for 60MPH; I'd expect more like 550F. 2-3PSI sounds right, though.
Remember, you don't *want* boost unless you are able to use the air. More pressure = more wasted power in spinning that turbo unit and compressing air.
But if you can use that air in combustion, it's a net massive plus.
If you're not getting black smoke, you've got plenty of air for the fuel being burned.
Old 02-17-2014, 10:18 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Not worth the money. If you want more power tighten up the wastegate and turn up the fuel. Ideally you dont really want boost just cruising, like macrobb was saying. 350* does sound a smidge low, but i guess it depends on rpm. If i drive 50 mine stay under 400, but if im doing 70 theyre 500-600, granted i have 4.11s too.
Old 02-18-2014, 07:46 PM
Thanks all for the replies. I think the low temp is caused by running 100% bio-diesel. They tend to run cooler. Now that I know, I am happy. Thanks again.
Tom
Old 02-18-2014, 10:19 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
the wrap and turbo blanket wont make it boost higher,but quicker.with no load,there's no need for boost as the others stated.once you put it under load,all that pressurized air really gives her a boot in the pants for hauling/towing.
if your looking to max what you've got,wrap everything you can,add a turbo blanket,intercooler and max the fuel.she'll boost even lower at no load cruse,but have more power and higher efficiency.
wrap;
http://www.ford-trucks.com/forums/at...1&d=1391219204
blanket:
http://www.ford-trucks.com/forums/pi...ctureid=149173
intercooler:
http://www.ford-trucks.com/forums/12...gen-truck.html
Old 02-19-2014, 11:31 AM
Tom,have you still yet to tune up your idi as was probably the issue you had back in '06:
http://www.ford-trucks.com/forums/54...idi-7-3-a.html
if your running an old tiered worn out ip and injectors that have pop pressures of half what they should be and who knows what for timing still,you could be down a whopping 50 hp or more by now and not even know it.
get your ip reman,drop in a fresh set of G codes,set the timing to 7 - 8 BTDC then do the above wrapping,and you'll think you set a whole new engine under the hood.intercool her and max the fuel and you'll think your running a 94-97 psd with 4.10's.probably even a bit stronger since we have more base compression to start with.been a long while since iv run those trucks now.
start here:
IDI Tuneup
Hypermax help - No boost? tgreening Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 48 04-18-2016 03:37 PM
Low Boost '94IDITurbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 03-26-2012 08:37 PM
Loss of boost pressure, under full load ? MCR500 6.0L Power Stroke Diesel 11 01-18-2011 07:41 PM
Unsustained boost when towing cavitation 1999 - 2003 7.3L Power Stroke Diesel 34 06-15-2010 01:28 AM
Want to lower EGT's PowerstrokeJunkie 1999 - 2003 7.3L Power Stroke Diesel 40 07-29-2007 12:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
