GUIDE: How to remove the Water Pump in a 1990-1997 4.0L OHV V6 Ford Aerostar - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 02-17-2014, 04:34 PM
Lee Binder Lee Binder is offline
Lee Binder is starting off with a positive reputation.
This guide developed working on my 1990 4.0L XL, which is part of the 1990-1997 series, so theroretically most if not all should also apply to ANY 4.0L V6 Van of that production period.
If you follow this guide, you will (in contrast to other guides of this job) NOT have to remove Alternator, Power Steering motor, Radiator, and Radiator fan shroud.
Some parts of this guide might sound familiar if you've done some homework already because they were taken from existing guides when they proved correct. I decided to write this guide because ALL of the guides out there have errors, some of which are severe (like lumping together 3.0L and 4.0L...) - and NONE of the guides was succinct enough to walk me all the way through.
Required tools & utilities:
  • K-D Tools KD 3472 – Universal Pulley Holder / 36mm Fan Clutch Tool Kit (recommended quality-level tools)
  • ½”, 5/8”, 10mm wrenches + ratchet(s) w/ these sockets
  • LOTS of ratchet extension & adapters..
  • Pipes as extensions
  • Flat-head screwdriver
  • Hose clamp pliers
  • Gasket remover solvent, razor blade scraper, Scotch-Brite Ultra Fine Hand Pad
  • Bright light or at least headlamp
During the job process on my 1990 model with one serpentine belt, ALL nuts turned out to be "normal" right-hand thread and loosened counter-clockwise. Each model’s fan clutch thread rotation should be imprinted on top of the fan shroud.
1. Remove the air hose going to the throttle body. The small hose towards the passenger seat simply pulls out.
2. Place the fan clutch pulley holder onto the nuts of the fan clutch pulley, then place the fan clutch nut removal tool around the 36mm fan clutch nut. To easier loosen the nut, best use a pipe which you push over the nut removal tool handle for better leverage. Hold the pulley tool with one hand, and push the pipe with the nut-tool inside with the other hand, apart from each other. This is better than shock-hitting the tool with a hammer to open it.
3. Once the nut is loose, you should be able to simply spin the fan loose off the pulley bolt thread by rotating it counter-clockwise.
4. Push the fan carefully toward the radiator to give you a little more room. You can take a sponge or similar to stuff it between fan top and shroud to fixate the fan, to create as much space to work as possible. This approach will keep you from having to remove the alternator and bracket.
5. Draw yourself a diagram of ALL the pulleys, and how the serpentine belt runs around them.
6. Put a 5/8” wrench onto the bolt of the belt-tension retaining pulley (the one underneath the lower right of the alternator, erroneously called “idler pulley”). Shove a pipe over the wrench at around the 11 o’clock angle position. Push the pipe down. That will pivot the idler pulley down and loosen the belt tension so you can slide the belt off the alternator pulley.
7. Push the belt away from the water pump area in way which creates most space around it (no need to pull out the belt completely).
8. To remove the four bolts that hold the pulley in front of the water pump, again use the pulley tool, and a ratchet with a ½” socket: hold the pulley in static position by grabbing two nuts with the pulley tool, and do the initial loosening of the next accessible nut with the ratchet - again with the "refined shock-and-awe brute-force technique”. DO NOT LOOSEN ALL THE WAY – ONLY WORK THE RATCHED UNTIL THE NUT HAS STARTED TO TURN!
Now rotate the pulley 90°, grab the next two nuts with the pulley tool, and the next tight nut with the ratchet. Continue until all 4 nuts have come loose. Once the 4th nut is loose, you can put the pulley tool aside, grab the pulley with your hands, and loosen then remove all 4 nuts 1 x 1. Store these nuts safely, e.g. in a zip-lock bag or closable container.
Pull the water pump pulley out of the engine compartment.
9. Remove the hoses from both sides of the water pump:
To loosen the lower radiator hose to the right, squeeze the hose clamp together (best with clamp pliers, otherwise with vice grips), push the clamp away from the pump down the hose, then carefully use a flat head screwdriver to push the hose off the pipe end on the pump.
The smaller heater return hose on the left side is held with a screw clamp. I was NOT able to get that hose off at this point.. so if you don’t, either – no worries - simply catch up AFTER unbolting the water pump.
10. Remove all 12 same-length 10mm bolts that hold the water pump onto the engine using both, ratchet and wrench, whichever most convenient, working from both, above and below the engine. Be patient, and enduring..
Once ALL bolts are loose, the pump should come off simply by pulling it towards you using your hands best wearing gloves, or if needed by carefully prying with a wide flat-head screwdriver where the top of the pump protrudes a bit.
In case the small heater return hose is still connected, you need to pull if off now. I had difficulties getting it off, but a combination of WD-40, flat-head screwdriver, and lots of twisting and turning did it somehow eventually.
11. Carefully pull the water pump out of the engine compartment, which might take a few twists and turns around the shroud and the AC hoses.
12. Now there is enough space to pull the fan/ fan clutch combo out – WITHOUT removing the fan shroud! Do this carefully and slowly – wiggle it out inch by inch whilst pulling the shroud top towards you to keep the clutch teeth from getting caught in the shroud plastic.
Inspect the fan! If it has cracks, you need to get a new one! Cracked ones damage the water-pump with their uneven spinning, and are bound to explode apart eventually, which is likely to cause A LOT of DAMAGE under the hood …
13. Remove any remnants of gasket on the edge rim of the water-pump’s engine part of the housing with gasket remover solvent, a razor blade scraper, and Scotch-Brite Ultra Fine Hand Pad (from 3M or similar)
Old 02-18-2014, 08:44 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
I've done this a few times, and most points are spot on except for one. You are NOT doing yourself any favors by leaving the shroud in place. You have to fight the tight space both in terms of being able to reach stuff, and in being able to get your parts in an out. It also increases the risks that you will hurt yourself as you work.
And no, I have never had to remove any other accessories, they are not in the way.
Old 02-18-2014, 10:07 PM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
I'm with Khan on this one when it comes to a water pump. I remove the shroud (I've owned four Aerostars that have had over a million miles), but in your case if you feel it needs to stay on, so be it.
Good point about the fan. A lot of the high-mileaged Aeros get cracks in the plastic fan. I think the last one I bought was from NAPA, but a quick check on RockAuto shows that Dorman and Four Seasons both have them listed.
Old 02-19-2014, 12:26 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
trying to fight the fan/clutch/water pump out past the shroud results in blood loss and fingers that look like they've been stuck in the blender.
I take the shroud out and the radiator also if it hasn't been out in a couple years and flushed with HD cleaner. I run a long radiator brush down the fill hole and knock the mineral growth off the ends of the tubes them flush and back flush.
Sure improves the wimpy cooling on the Aero.
Now if I could just do something about the floor cooking my feet in 100d F+ heat.
the Aero's have the worst cooling air flow on the floor in summer. tried the foil bubble auto insulation, extra fans on the sides.
A/C will freeze my face off, but my feet are heat blistered on the hot days.
Old 02-19-2014, 04:55 AM
keep on pumping good info, folks - I'm overwhelmed by real life right now and won't be able to focus on this till the week-end.
Thanks,
Lee
Old 02-19-2014, 03:28 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
I think I removed my fan with the shroud after pulling the fan clutch off the pump pulley. That's about the easiest way to get those two things out of the way so I have room to remove the pump. I think I left the belt on while loosening the bolts on the pump pulley; can't remember now.
While you've got the pump off, check all the bolts around the front cover to make sure they're tight. I had one of the lower ones loosen up some time AFTER I replaced the pump, and it started to leak coolant. I think it was the two-sided bolt that also serves as the anchor for a bracket that held the wires for the crank position sensor. There is a second nut on it for the bracket, but make sure the bolt itself is tight.
THE CREAM PUFF PROJECT...... paintubturner 1994.5 - 1997 7.3L Power Stroke Diesel 65 Today 01:33 AM
F-150 rear end shudder fixed. New limited slip clutch pack installation how to. Tnelson82 2004 - 2008 F150 4 10-18-2015 04:48 PM
Radiator fan clutch (thermostatic) replacement. wpnaes Excursion - King of SUVs 4 02-02-2015 12:35 PM
HOWTO - Complete Guide to Ignition Conversion (DUI) , Comptuter Delete, Emissions KsCop '80-'86 HOWTO's 8 06-30-2014 01:48 AM
Replacing the Water Pump Info fixxxer-upper 6.0L Power Stroke Diesel 23 10-10-2013 05:11 PM
Tags
1990, 1997, 4.0l, ford aerostar, ohv, removal, replacement, v6 engine, water pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
