Switching 330 from 2 barrel to 4 barrel - GTG or HELL NO...?!?!
Would switching the stock 330 from 2 barrel to 4 barrel "wake it up" -
More power and better efficiency - Or is the cam too mild / exhaust too restrictive to know the difference?
Anyone try this swap - And if so - What new intake manifold / CFM carb did you use?
If you're going to keep your FT engine, get a copy of Steve Christ's book "How to Rebuild Big Block Ford Engines". The FT is basically a close relative of the FEs (332, 352, 360, 361 (Edsel), 390, 406, 410, 427, 428) and this book will tell you in Chapter 3 about parts interchange possibilities between FTs and FEs. No, small block stuff will not interchange. Most F100 vendors sell this book.
Green1978F250owner
12-11-2018 10:07 PM
Jakes69
08-30-2003 03:22 PM
