OBD2 Problems (tuner)
Hey guys. I'm new to the forum although I've been using the info for a while now.
Anyways, I recently baught a h&s tuner and installed a dpf delete kit.
Everything works great when the truck is not plugged in to the tuner although when I do plug it in, the truck keeps throwing a communications code and goes into a limp mode until I delete the code. I believe it was p0073 but i maye be mistaken. Regardless it has to do with communicating through the obd2 port. I sent the tuner in to get checked out and it turns out its something to do with the truck. I've checked all the fuses and tried to check for broken wires.
Anyone have any ideas of where to look next?
Thanks
Thanks
Dutch13
Give this link a look. It may help.
http://www.justanswer.com/ford/23h2k...mes-u0073.html
Also with the 6.4 you could ask in that forum
6.4L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Sean
Sean
04F-250mark
02-19-2010 11:56 AM
