E4OD to ZF 5S-42 swap break down - Ford Truck Enthusiasts Forums
Old 02-17-2014, 12:05 PM
myakkacracka's Avatar
myakkacracka myakkacracka is offline
myakkacracka is starting off with a positive reputation.
I just performed a E4OD to ZF 5S-42 swap into my 1995 F250 5.8L 2wd. thought id share my experience to help others wanting to perform this swap. Sorry for the length of this I thought id break it down. And im no writer so if its confusing feel free to ask questions.
Gathering Parts
<OI picked up the trans at a junk yard found it on a pallet already pulled so Iím not sure what kind of truck it came out of but it looked good i opened the PTO cover, ran it through the gears, checked input shaft bearing play and didnít see any problems so I grabbed it. The model tag said it was a '88 model so I purchased the flywheel, clutch, pressure plate, throw out bearing/slave cylinder and hydraulic line for a 1988 F250 5.8L
I went back to the junk yard and found a 1993 F150 4.9l 5speed and I got the pedals, cross member, the clutch switch, the plate that holds the master cylinder on the firewall the center hump cover and the harness for the reverse light and speedo. The shifter and boot was gone so Iíll have to come up with that later.<O</O
Trans Install
With the new flywheel, clutch kit, Slave cylinder and pilot bearing installed (looking back I wish I would have used a pilot bushing instead)
<Oit all bolted up fine. I did have to get longer hardware for the flywheel but Advanced auto parts had "flywheel bolts" on the shelf that worked fine. The crossmember fit fine besides one frame bracket didnt clear the exhasut so I'll have to figure that out later. the tranny mount off the automatic was good and fit fine so I reused it.The top two bolts on the bell houseing needed to be longer I found some on the shelf so I cant remember the length of them. </O
The pedals
Before you install the pedals there is a tab that holds the shift cable (for the automatic) that has to be bent out of the way. It is part of the column and looked like a pain in the a$$ to remove. The upper stop for the clutch pedal hits the tab and you wonít be able to get all the bolts lined up. I purchased a master cylinder for a 1995 F2 and it just bolts in where the block off plate is and thatís were that plate I got from the junk yard bolts in to hold the master.
<O</O
Clutch Switch <O</O
There is a harness above the clutch rod that has a cap in it (aka a jumper for the clutch switch) pull the cap out and plug it into the switch and now you have to push the clutch in to start it. Me being a ďManĒ wasnít gonna hook it up but if for some reason someone else has to drive the truck I thought it would be a good safety feature <O></O>
<O</O
Wiring Harness<O</O
The harness plugs under the brake master cylinder on the plastic inner fender and you can remove the automatic one and install the Manual one. If you have a V8 there is a o2 sensor that is past the trans and in the harness for the transmission you can find a V8 harness or I pulled the automatic one down and rebuilt the manual one to hook up the o2 itís easy to do.
The Driveshaft <O</O
It had to be lengthened by about 16". With my extended cab long bed it measured 49" from the face of the yoke to the center of the carrier bearing and I had to use a conversion joint to get down to the size of the yoke on the tranny.<O</O
<O</O
Bleeding the clutch <O</O
I fought this for about 3 days but in the end this is how I did it. Before you install the master cylinder and the line bench bleed it. Hook up the line up and install the rod to the master the put fluid in it and push the rod against the wall and pump it until the rod only moves about a ľ inch it will be really hard to push in. this gets all the air out of the master. Then install the master plug the line into the slave and I found it only bled when I cracked the bleeder loose then pushed the pedal in and after tightening the bleeder hold the pedal down for about 20 seconds. <O</O
<O</O
Center hump<O</O
With the flooring pulled back after removing the kick panels and door sills you will have access to the center hump. 4wd models you just swap the center humps out for the one with the shifter boot hole, trim your floor covering accordingly and your good to go. On 2wd models you will see the outline in the floor I used a jig saw and cut about and 2 inches from the outline and it seemed to be enough clearance for the tranny to fit. The floor covering wonít work for the raised center hump so you can make another junk yard run or LMCtruck.com has flooring available.<O</O
<O</O
Fluid<O</O
I asked the boys at Advanced what fluid it took and he showed me on there computer it says it needs 80w90. ???? not setting right with me I didnít buy anything and did some research and found that it required Dexron III/MERCONģ XT-2 QDX or DDX equivalent<O</O
http://www.zf.com/media/media/document/corporate_2/downloads_1/usa/lcv_3/S542_Transmissions.pdf so I used the synthic version Mercon 5<O</O
<O</O
The Starter<O</O
In the install I noticed my original starter fit perfect and bolted right in but will running the truck made a horrible sound and I swore it was the junk I bought from Advanced auto parts but members ArdWrknTrk and 88n94 (thanks again guys) informed me that there is a starter for the automatic and one for the manual. So going with the theory of buying everything for the trans using the same model year I bought a starter for a í88 F2 5.8 and it turns out I wonít fit thought the plate thatís between the motor and trans so another trip to the auto parts store and I got starter for the trucks year í95 and it worked great.<O</O
<O</O
Post Swap <O</O
Iíve been driving it for about 2 weeks now and the only thing I lost was cruise control which must be part of the harness I took apart but Im gonna work on that. Everything else works great I made a shifter out of stainless for a custom touch still gotta get my floor cover and boot installed but all in all im glad I did the swap. <O</O
<O</O
I hope this helps anyone tryin to perform this swap im sure the M5Od is much the same feel free to ask questions I hope it wasnít too difficult to get through.<O</O
<O</O
Old 02-25-2014, 09:44 PM
RTSinDallas RTSinDallas is offline
RTSinDallas is starting off with a positive reputation.
Thanks for the write up. I've been stockpiling parts to swap a ZF 5s-42 for the C6 in a 1981 F250.
A quick question, why would you have used a pilot bushing instead of the bearing, if you had it to do over again?
Old 03-04-2014, 03:12 PM
I just feel like the bearing is more prone to failing and Ive heard of these bushings that have oil in them and when the heat up the oil seeps out.
Old 01-08-2016, 11:17 PM
cheeseman70 cheeseman70 is offline
cheeseman70 is starting off with a positive reputation.
I know this is a long time since posting, just curious if you ever got the cruise working? I did a swap to a manual and I can't get the cruise to work yet.
Old 06-16-2016, 10:45 AM
Sorry its taken me so long. I have not gotten the cruise to work ive tried a few thinga but im guessing it needs info from the trans. Ive taken the module apart and tried to bypass the controls with my own i can get the clutch to lock and unlock but i cant get the servo to rotate at all im thinking about making a cruise servi out of a window motor and use a up down window switch to pull the throttle body cable in and out. It would be unsafe but it might work
Old 06-16-2016, 11:14 AM
Actually I do have my cruise working. What you have to do is take the wire from the overdrive button on the end of the automatic shift lever, and solder it on to the correct connection on the clutch position sensor. If this isn't enough info let me know and I can try to get exact wire colors, etc. Everything works now like it's supposed to. Tapping clutch or brake disengages cruise, etc.
Old 06-16-2016, 11:23 AM
If you look at the ECM wiring diagram, there is one pin (#29) that takes different wire color for automatic versus manual tranny. So instead of trying to figure out harness, etc, I just changed what that wire went to. I love the manual and the fact that the cruise works!!
Old 06-16-2016, 11:34 AM
Thats amazing i looked high and low for a wiring diagram. So all u did was run a wire from the overdrive swith to the clutch switch. Do u remember what pin u hooked it to on the clutch switch. Does it just need 12v or something
Old 06-16-2016, 11:43 AM
Did you replace the transmission harness with the manual one or leave the automatic in place
Old 06-16-2016, 12:06 PM
My pickup is not at home right now (the clutch plate broke between dampening springs and center splines) so I can't go look at it. I believe the wire from shift lever is tan with white stripe.
Old 06-16-2016, 12:07 PM
I did not change wiring harnesses, I think I did wire the reverse switch in manual transmission directly to the wires going to the reverse lights, not for sure about exactly how I did that. I also have a pdf of the wiring diagram for 2002 which seemed to work for my 2001. I don't know how to post it, or if you want to email me direct I can email it to you if you want. my email is jason at jasonwiebedairy.com
Old 06-16-2016, 12:18 PM
So your dealing with a 01 7.3? My trucks a 95 5.8. But i think you gave me an idea on what to look for on figuring out the issue.
Old 06-16-2016, 12:24 PM
Wish you well. Let me know how it goes, also if you have any more questions for me, just ask. I know I went a long time without my cruise working, even tried changing pcm from a manual transmission pickup, etc., and spent a long time studying wiring diagrams!!
Old 06-16-2016, 12:33 PM
Yea same here new pcm and everything. I appreciate the help. I might jump on it tonight
08-12 Crew Cab Front Seats Into Excursion BuiltFordTough! Excursion - King of SUVs 35 02-22-2016 12:09 PM
Color code and under hood paint '64 F-100 HAMS64 Paint & Bodywork 7 06-01-2015 10:16 AM
Tilt Steering Column Problems keithredfirebird 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-30-2010 08:28 AM
Iam desperate for help on my solenoid switch please r23k4u1968 1967 - 1972 F-100 & Larger F-Series Trucks 11 04-14-2010 03:15 PM
85 F250 XL Electrical Part 2 jobrewer1983 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-04-2010 07:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
