71 F-100 4x4 Front Axle Swap
Old 02-17-2014, 09:30 AM
Reddogg0_1's Avatar
Reddogg0_1
Reddogg0_1 is offline
I have a 1971 F-100 4X4. Before I lift it and get bigger tires I want to do a front axle swap to get disc brakes. I could probably get my hands on a dana 44 from a 1979 F-150. Will it bolt in? Are the spring mounting dimensions the same? When I purchase the lift will I need to get coils for a 1979 F-150 or a 1971 F-100? Or are the coil spring diameters the same? Thanks!!!!
Old 02-17-2014, 09:43 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
IIRC, the spring cups on 78/79 Dents are different and the steering linkages (tie rods) have thicker shanks. Your 71's tie rods will bottom out and cannot be tightened. Ya might want to consider doing the whole sh'bang with integral PS from the 78/79 too.
Order springs spec'ed for the 78/79. If needing to piece together a system, contact Rocky Mountain Suspension outta North Carolina. Their customer service for these situations is really good.
Welcome to FTE.
Old 02-17-2014, 10:58 AM
Reddogg0_1's Avatar
Reddogg0_1
If I find a 79 Dana 44 I will take all the steering and track bar. I guess what you are saying is that it will fit though? The frame widths are not different between 71 & 79? Should I try to get the coil frame mounts from a 79 as well??
Old 08-03-2014, 10:44 PM
gnwatton's Avatar
gnwatton
gnwatton is offline
Did you get this to work? I am looking at doing the same thing.
Old 08-04-2014, 08:41 PM
Azcannon's Avatar
Azcannon
Azcannon is offline
my 71 f100 has a 78 bronco complete front end ( 4x4 ), works well , has the power steering box from the bronco also. coil towers even sway bar which I still need to remove. po installed it , drives fine. He did NOT do anything to the brakes though so I am changing the manual brakes to power assisted and new prop valve at this time. rears would just lock up when you hit the brakes.
Grape Nehi
02-18-2017 08:49 PM
shannonguy
22
07-08-2015 11:33 AM
Beastmaster
12-28-2005 09:11 PM
elliott
10-09-2002 09:12 PM
Quick Reply: 71 F-100 4x4 Front Axle Swap
