Lets talk auto transmission tuning
my 99.5 DRW truck is getting a chip soon. It currently has a Banks Big Hoss system on it. Exhaust Brake, exhaust, six gun tuner, Trans-Command, etc. Its also got the non-CA spec BD Power Thruster II. Basically a non-ballbearing 38R.
I will be eliminating the Trans-Command, and going with a PHP Hydra Chip with custom tunes. I have been talking with Tony at Total Diesel Peformance about what I want the transmission to do when towing.
I want to try out Tony's tunes since he gives free lifetime reburns when you purchase the Hydra through him. Over the summer I plan to upgrade to a stage 2 towing transmission and 160/100 injectors. So, not having to pay for all new tunes as I upgrade is a good selling point.
Some of the other things I want that Tony can do are:
1. OD off in all tow tunes under 45mph
2. Torque Converter lockup in all tow tunes below 40mph when manually shifting into 1st and 2nd gear.
One thing I would really like it to do when towing is to provide full torque converter lockup under decel for the Banks Exhaust brake. However, Tony told me he doesn't do that with his chips. IIRC, I think Jody at DP will do that. Its mainly to help control temps on decel in the tranny. I am curious about a dash switch that I could wire in for full lockup in those situations.
I routinely tow close to 26K combined over I-70 in the Rockies. So, full lockup on decel on the backside of Eisenhower tunnel is a much wanted option. Especially with the exhaust brake.
Any other transmission tunes you guys would recommend having written into the tunes?
If I were towing that kind of weight in the mountains I'd have a stick shift so the transmission did what I want when I want it to, but I realize I'm the oddball.
If I had an auto tranny, I think I would prefer a manual torque converter lockup switch instead of relying on some tuner to do the job for me.
There's also something to be said for free reburns. My wife got hers re-done recently because she wanted to change the order on the switch. Tony just laughed and told her to write it down this time.
And, yes, I have gauges, and a 6.0L tranny cooler in the works.
#2 can't be done. The trans tuning can't differentiate TC lockup between auto and "manual" shifting in the PCM. The only thing that does happen is when you manually throw the shift in either 1st or 2nd is that it mechanically prevents freewheeling (and you can't duplicate it with the tuning, it's already been tried).
You'll have to rig a lockup switch and do it by hand.
I will have to say the best trans shifting I've had is by DP Tuner. I had a Hydra for a bit (still own it, but I loaned it out) and while it had only the PHP tunes, which could have been massaged....the DP, which Jody worked on 2x, is much better.
So look for a tuner that has a good track record of trans tuning and work it out with them.
#1 is easy to do.
Not sure about item #2....I think the PCM is able to lock the TC in those gears under heavy throttle conditions already so I am not sure what you are looking for here...
Banks Power | 99-03 Ford - 7.3L Power Stroke>>SmartLock® Trans Brake
This is what I use and it's completely automatic.
If you use a chassis cab calibration then item #1 will be resolved by default.
See here:
See here:
Basically, I am not sure if I should disconnect the TransCommand and Safe lock systems or not. I haven't been able to get a definitive answer on it. And I don't want one of the systems to screw something up.
I am not looking for a Decel tune itself. Rather full lockup on the torque converter when decelerating down mountain passes. It appears that the Smartlock will still function properly and I don't have to remove it.
You MUST remove the TransCommand before using the Hydra Chip. Actually, you don't have to.....it's just highly recommended. The TransCommand will NOT work well with aftermarket switch on the fly calibrations. Do you happen to have the bypass plug by any chance?
The SafeLock module will work fine with whatever chip you wish to run. It is positioned between the PCM and transmission so it effectively has the last say in the TC lock up process.
Mine has the SmartLock on it. The Banks system is really a hard thing to pin point though. Especially when piggy backing it with the Hydra chip.
