Vibration when braking after replacing brakes and rotors. - Ford Truck Enthusiasts Forums
Old 02-16-2014, 05:36 PM
Michael Naquin Michael Naquin is offline
Michael Naquin is starting off with a positive reputation.
I have a 2005 Ford F150 2wd I had bad vibration everytime I would brake. I had the rotors and brake pads changed and it seemed to fix the problem. It doesn't shake anymore when braking at slower speeds, but if I'm doing over 50 mph it will shake every time I touch the brakes. Does anyone know of something else that could be causing this to happen?
Old 02-16-2014, 06:55 PM
7.3 down's Avatar
7.3 down 7.3 down is offline
7.3 down is starting off with a positive reputation.
good vibrations
According to my local machine shop dude it is not uncommon for new brake rotors to have run-out or not to be as flat as the manufacturer claims. He advises customers that are buying new rotors to have them turned before installing them. I first thought of this practice as an easy way for the dude to make some extra money, but experienced the same problem you have after replacing the rotors on my F250 4WD. I did not experience any vibration prior to replacing them(just worn out) but I could have sold my front end as a sextoy for the ladies after installing the new rotors. The box claimed that they were ready to install and had beautiful cross hatch marks on the braking surface. I did learn however the proper procedure of taking my front hub assembly apart(courtesy of 4WD) Long story short. I would not be the least surprised to find out that your new rotors are simply not within spec. and need to be turned.
Old 02-16-2014, 07:44 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
You should not have to ever turn new rotors , if they are truly bad they need to be REturned , not turned , I get my rotors from autozone , and have never had the slightest problem with them.
By the way , rotors on a 4wd are different than yours.
I assume you had a mechanic do the work ? If so take it back , might just need to be bedded in.
Old 02-17-2014, 01:57 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
I used to think the same way until a friend who owns a brake shop told me it's not uncommon to have brand new rotors (any brand, including customers who provide their own rotors) needing to be turned.
Then it happened to me 2 years ago. After 20 years of doing my own brakes, I bolted on a set of new rotors and had brake pedal shimmy when I went to bed the new pads. I pulled the new rotors and took them to my buddy's shop and he turned them for me.
Stewart
Old 02-17-2014, 02:29 PM
Stewart
Why not just take them back where you bought them , and exchange them ?
They were obviously defective , right ?
Old 02-17-2014, 03:41 PM
Stewart_H's Avatar
Cryo treated rotors purchased online.
I woulda, but it was just easier to get them turned.
Stewart
Old 04-07-2014, 12:08 AM
442w30 442w30 is offline
442w30 is starting off with a positive reputation.
Worn out brake hardware...Had all the same problems and once I changed hardware all was/is good.
Old 04-08-2014, 03:58 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4 2004 xlt 5.4 is offline
2004 xlt 5.4 is starting off with a positive reputation.
rear brakes not adjusted properly will cause a vibration
Old 04-08-2014, 08:06 PM
Quote:
??? How do you "adjust" rear disc brakes ?
Old 04-08-2014, 09:00 PM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
He's taking about the emergency brake I think.
Old 04-09-2014, 01:30 AM
Quote:
leaving the e brake "on",,,,will cause a heck of a shake , but it is more normal for them to be loose than to be too tight,...
Old 04-09-2014, 01:00 PM
Yes the emergency break may cause it sorry for confusion
Van shakes when slowing down redpumas18 1968-2013 Full Size Vans 4 06-23-2014 09:18 AM
Brakes Vibrating rbruno 1999 to 2016 Super Duty 6 08-29-2013 12:58 PM
2003 f250 clunk, rattle, and shaking dustys7.3psd 1999 - 2003 7.3L Power Stroke Diesel 5 06-17-2009 02:47 PM
Vibration when brakes applied jzleach 2004 - 2008 F150 4 05-16-2009 09:40 PM
Brake Surging Issues THEDON117 1999 - 2003 7.3L Power Stroke Diesel 6 03-24-2009 01:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
