First Tow with the Eco Boost - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Old 02-16-2014, 01:21 PM
Brandon D's Avatar
Brandon D Brandon D is offline
Lead Foot User
Brandon D is gaining momentum as a positive member of FTE.Brandon D is gaining momentum as a positive member of FTE.
Drove down to MN on Thurs to pick up a new camper I bought. Trailer is 8000lbs and 34ft and the truck handled it surprisingly well. I got 17 MPG on the 1100km trip down and averaged 7.5 MPG on the trip home. All in all it towed better than I thought it would but I still miss my F350 for jobs like that!!
Old 02-22-2014, 09:32 AM
keyston44 keyston44 is offline
keyston44 is starting off with a positive reputation.
Did the trailer flatten out the springs much? Did the weight distributing hitch level it out well?
When I had a trailer like that it almost completely squished my 2000 F250. I had to add the air bellows to level the truck out.
Key
Old 02-24-2014, 11:18 PM
Brandon D's Avatar
Lead Foot User
The trailer did squat the back end down quite a bit but the load leveller hitch helped tremendously. It sat damn near level once we got that hooked up. To be honest I fully expected it to squat a lot more than it did.
Old 03-01-2014, 07:38 PM
EcoboostKev's Avatar
EcoboostKev EcoboostKev is offline
EcoboostKev has a very good reputation on FTE.EcoboostKev has a very good reputation on FTE.EcoboostKev has a very good reputation on FTE.
Nice looking setup! What gears do you have?? You should look into getting the telescoping tow mirrors. Much nicer for towing...
Old 03-06-2014, 07:46 PM
Brandon D's Avatar
Lead Foot User
Thanks! I've got the 3.55 gears and I would get the mirrors but I won't be towing the trailer much. Most likely to a lot at the lake and then leave it there. I'd definitely need an F350 again if I planned on towing it all the time!!
Old 03-24-2014, 10:24 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.conger is gaining momentum as a positive member of FTE.
Quote:
Check out etrailer.com I've got those snap on tow mirrors and they look and work great. I'm not a fan of the big mirrors on my F150 they just look to large on a non lifted truck.
Old 04-03-2014, 11:44 PM
Brandon D's Avatar
Lead Foot User
Quote:
Thanks conger, I already have a set of strap on mirrors that I use. They're not perfect but they work good enough for the small amount I'll be towing this trailer. Cheers
Old 04-04-2014, 01:00 PM
Torklift Sheryl's Avatar
Torklift Sheryl Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
These trucks sure do great towing! I just wanted to add a suggestion for a suspension upgrade with Torklift StableLoads.
They are going to greatly reduce side to side sway, sag and trailer bounce. It also easily disengages when you're not towing and will make your ride much smoother.
-Torklift Jen
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
A Data Point ... Tires U235Fishin' 6.7L Power Stroke Diesel 6 11-26-2016 10:15 AM
Weekend Towing Expectations! Richwon4 Excursion - King of SUVs 11 05-22-2016 04:02 PM
Towing Mileage dg250 EcoBoost (all engine sizes) 20 11-15-2013 09:48 PM
First Tow with 6.2 kmonty2 6.2L V8 35 07-25-2011 11:27 PM
Trip Report 2700 miles into trip StanleyZ 6.4L Power Stroke Diesel 23 08-27-2009 07:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
