Question for dark siders
#31
So I rebuilt the carb. Still not sure what model I have. It has a number on the front of the bowl of 80457-2 3171. On top of the bowl is R7809. I have been told the power valve has blown(I knew there was reason for my dislike of Holley carbs). I bought one at O'Reilly's which was a 3.5. Was not sure what was in it. When I pulled the fuel bowl off I found it has a 6.5. I did not keep the old one and did not think to look at it. My problem is since I don't know if I bought the right rebuild kit, I don't know which size is the right one.
#32
#33
#35
First of all, I can't believe OReillys had ANY PV's. A 3.5 is pretty low, IMO, usually they come out of the box with a 6.5, or even a 7.5. But as long as the PV isn't leaking by, it wouldn't affect starting.
Could your filter be totally plugged?
I have to say I'm reminded of the old saying, 90% of carb problems are ignition problems...
#36
I went back to OReillys and got the 6.5. Installed it and it seems to be running good now. I haven't reved it up too high or stuck my foot in it on test driving. When I reved it up after the rebuild, that is when it backed fired and took out the PV. As far as ignition, I put in new rotor and coil. I have an HEI distributor. I figured once I had the carb working I would put in new plugs and wires next. The only issue I have now is it seems the choke is either not kicking in or fast idle is not kicking in. It is probably just an adjustment, but I didn't mess with that when I had the carb apart so I figured it would have been still like it was before the rebuild. Thanks for all your help on this.
mrsteamy
06-01-2010 08:44 PM
