What do you think of the 6.2 Transmission - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 02-16-2014, 11:31 AM
RRRAVEN RRRAVEN is offline
RRRAVEN is starting off with a positive reputation.
Hi everyone-
I have about 2500 miles on my 2014 XL350 CC 4x4 with 4.30 gears and I was wondering what others with the 6.2 think of the transmission action/throttle response?
If I'm rolling at a slower speed and I just romp on it the truck just seems to rev up and wind itself up tight but not really go anywhere until it catches the next gear. If I get the thing rolling along pretty good and then mash it the things rips! My 2002 with a 6.8 V10 4.30's kind of did the same thing.
My 6.2 tranny feels great when I'm on the throttle steady but when I'm in heavy traffic, behind grandma, coasting and on and off the gas it seems like the computer gets confused and it doesn't know what gear it wants to be in. RPM's are up and down.
I really like the manual option as you can hold it in the gear you want or shift it as you want up or down with a flick of the finger.
The tranny also seems a but sluggish when it is cold. I think the electronic solenoids like the fluid to be warmer before they work smooth.
Just wondering what others think of their 6.2 tranny action.
Later-
RRRAVEN
Old 02-16-2014, 11:52 AM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
Same tranny as the 6.7 btw.
My shifting seemed to get more predictable
@ 5000mi. I'm getting used to it now.
Old 02-16-2014, 01:28 PM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
so far I like it..i got the 6.2L with winter being super cold I let it warm up,, but I like it so far over my 5.4 tranny. I agree it is not neck snapping putting along behind grandma, I think the weak link is 3 to 4th..seems theres a tad of a lag before she goes,, but I only have 1600 miles on mine and will see in spring if warmer temps helps..i do like this 6 spd tranny.
Old 02-16-2014, 02:48 PM
kas83 kas83 is offline
kas83 is starting off with a positive reputation.
I noticed a huge difference in my uncles Raptors shifting after tuning it, even in the economy level. Fords strategies don't seem very conducive to longevity IMO.
Old 02-16-2014, 09:56 PM
claycomotrucks1991's Avatar
claycomotrucks1991 claycomotrucks1991 is offline
claycomotrucks1991 is starting off with a positive reputation.
Takes some getting use to but it's ok could be a lot better design but Ford hasn't fix the problems very fast!
Old 02-16-2014, 10:28 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
Want to hear something funny? My company bought 12 new 6.2L F-250's. A few of them shift really nice, but the rest hunt around for gears, have delayed downshifts, and sometimes pause between shifts. No transmission failures yet though.
Old 02-16-2014, 11:55 PM
onlydjmac's Avatar
onlydjmac onlydjmac is offline
onlydjmac is starting off with a positive reputation.
Unless your towing. Tranny is always hunting.
Old 02-17-2014, 06:10 AM
On the drive home from work yesterday I started playing around a bit with the auto/manual and gear lock out on the transmission. If you have the tranny in D and then toggle the +/- button the gear indicator lights light up so than you can actually see what gear the tranny is in while you are drivng. That gives you a better feel for what the transmission is actually doing while you are driving. Another thing you can do while in that mode is lock gears out, say to stay out of 5th and 6th while in town or in heavy slower stop and go crap. Just toggle the minus (-) button and the 6 light will go out, do it again and the 5 light will go out. So now you have 5th and 6th locked out and you will only see the 1st thru 4th indicator lights lit. All of this is in the owners manual. I've read that section a few times but only messed with it for the first time yesterday. I guess it just takes getting used to and just getting familiar to a modern automotive transmission control unit and how it was programmed from the factory. Is it optimal? Who knows? At least it can be aftermarket programmed if that's your deal or Ford can flash program it with an update it is available.
Old 02-17-2014, 07:21 AM
That function has been around for the past 3 years. I do like the fact you can lock out some gears if you prefer but just be prepared for worse fuel economy. although when your driving around town with the stop start by the time you get to 6th your looking to slow down..But it is the trade off to better mpg's as you drive. I like this tranny over the last SD I had with the 5.4.. that was a slow dog,, at least this 6.2 seems to have more getup..Nice to have choices for your driving needs..
Old 02-18-2014, 11:02 PM
eberlestock's Avatar
eberlestock eberlestock is online now
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
I have a 2012 and it acts just like yours. I prefer the 5 speed in my 06 V10....that is until I plugged in a superchip. The tuning it provided the tranny makes it work much better. Big change in the way it shifts. Still sluggish in the cold though.
Old 02-19-2014, 06:57 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Had the same experience but towing it worked like a dream. Now that it is 5 Star tuned it just is wayy to much fun all the time.
Old 02-19-2014, 07:01 AM
Quote:
I see guys are adding modified computer chips in there 6.2L. It changes the shift points of the truck. Do you find any fuel mileage increases with these chips or is it just faster throttle response and does that diminish your MPG's?
Old 02-19-2014, 02:22 PM
onlydjmac's Avatar
From what I have heard, the tune comes with a contagious disease called WOT (Wide Open Throttle). This causes a decrease in MPG. But that was just the drift I got reading posts on here.
LOL
Old 02-19-2014, 02:30 PM
There are mileage gains to a degree but it is way more about how the engine and transmission respond in everyday driving that makes the 5 Star tuning worth while. And the increase in power for towing or the disease refered to above is a nice benefit as well.
Old 02-19-2014, 06:37 PM
I have noticed no increase with the superchip as far as mpg. The truck just feels much more responsive, like ford should have made it.
2017 6.2L super duty owners Strokin-A-2010 6.2L V8 96 01-20-2017 05:27 PM
6.2 tuner with different rear diff's snickers104 6.2L V8 5 12-09-2016 06:43 AM
gas or diesel?? oklarado 2017 Super Duty 28 11-18-2016 08:01 PM
Anyone looking for a 2017 6.2 with 4.30 gears? PFG 6.2L V8 4 08-31-2016 11:27 PM
2002 F750 Dump Need Opinions on Potential Purchase RRRAVEN Large Truck 4 10-21-2013 12:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
