OBDII GAUGES FOR 14 ECOBOOST
I am looking for gauges for my 2014 XLT ecoboost that will monitor boost, Water Temp, Oil Pressure, and volts. The dash gauges are fine but I do not like the way they are basically idiot lights. at least I can go into the screen select gauges and get a digital temp read out.
I looked at scangauge, I have a scanner but it does not read boost and it is hard to read while driving. Any suggestions ? I did see one that was in a gauge pod but they just talked about the pod not the gauge.
I bought an Edge Monitor CST I think, for my 2013 Eco which plugs into the OBDll and can show more than you could imagine. It has places for 7 things to display the way I set it up. Turbo pressure was intake manifold pressure and there was no exhaust temp without an addition but there is cylinder head temp. I monitored volts, intake pressure , coolant temp, head temp, spark advance (very important with an Eco), etc. and was very happy with the product. I removed it when I sold the truck for my 2018. At this time they don't have a down load for the 18 yet but expect soon. I don't have my truck yet so no big deal.
This is NOT a tuner, you can get one of those if you wish, but just a monitor. The tuner can monitor also. Neither are cheap but I like their products.
I use the Veepeak wifi version for my iPhone with dashcmd and then the scantool obdlink mx Bluetooth for forscan stuff. The scantool is better but Iphones have to use wifi 😢. I also have the f150 ecoboost towing dashboard for dashcmd
It is a dashboard option that the dashcmd app has. I don't know how to view them online but through the app you can select a bunch of different dashboards. Basically it changes what gauges are visible to view in real time. The f150 towing one allows for boost, coolant temp, knock/timing, mpg, speed (either gps or based on obd port), rpm, gear, and some others.
messeswithtrux
11-02-2007 08:16 PM
