DSII Replacement Connectors - Ford Truck Enthusiasts Forums
Old 02-16-2014, 12:44 AM
bruno2's Avatar
bruno2 bruno2 is offline
bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.
Does anybody know of a source that sells replacement ends for the DSII connectors that go to the ignition module and dizzy?
Mine are very corroded and melty. The new parts had new plugs on them of course, but I need to replace the ones on the wiring harness too.
Old 02-16-2014, 01:07 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I've seen this kind of stuff at the local NAPA store.
Old 02-16-2014, 06:34 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I replied in your torque converter thread.
Old 02-16-2014, 08:48 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
And I bookmarked all that stuff. So, when you forget.......
Seriously though, can we order the stuff from the Motorcraft catalog from a Ford dealer? Or?
Old 02-16-2014, 09:22 AM
pedant
i think if you have a Motorcraft part number you can probably order from a parts store.
You can buy Motorcraft filters, plugs, alternators and other stuff, right?
They show their own numbers in addition to the Ford P/N
Old 02-16-2014, 02:06 PM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
I have a sticky in the How To section with the part numbers. If you google the part number, you'll see all sorts of sources to choose from
Duraspark II/HEI conversion failed sixofspades Ford Inline Six, 200, 250, 4.9L / 300 20 05-19-2016 03:46 PM
DSII swap tomorrow VictorF150 Ford Inline Six, 200, 250, 4.9L / 300 32 01-22-2015 08:50 AM
Duraspark II/HEI conversion failed sixofspades Ford Inline Six, 200, 250, 4.9L / 300 1 02-14-2014 08:23 PM
Adding Dura-Spark II to a "custom" 72 F350 Swede427 1967 - 1972 F-100 & Larger F-Series Trucks 4 10-09-2007 04:01 PM
Duraspark Swap Problems! doctorolds Electrical Systems/Wiring 21 07-31-2007 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
