numberdummy help - Ford Truck Enthusiasts Forums
numberdummy help
Old 02-15-2014, 04:13 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
numberdummy help
I would like to know what 8 or 9" rears ford made that are 56" drum surface to drum surface. Thank you in advance, much appreciated, Sir.!!!
Old 02-16-2014, 12:53 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Quote:
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
57" is narrowest stock. You can get rear axles narrowed to almost any width you want. You also might want to check www.racingjunk.com
Old 02-16-2014, 03:11 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
Mavericks are the narrowest 8"
57-59 Ford wagon are the narrowest 9"
But none are 56" drum to drum.
http://www.mustangsandmore.com/ubb/F...imensions.html
Old 02-17-2014, 02:15 PM
ZOOT's Avatar
Thanks for the info, Ax, Old, I sort of another thread going about finding a rear for the Model a coupe I'm going to work on. Ax, thanks for the thread about 4 links and triangulated rears. I'm gonna stop this thread cause this has the same subject, Thanks again.
Drum brake width? jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 11-13-2013 02:20 PM
Need help - brake measurement aussiecowboy 1957 - 1960 F100 & Larger F-Series Trucks 2 06-24-2013 09:13 PM
Brake rotor selection help! (First Post) Captain Caveman 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-09-2010 04:07 PM
77 ranchero rear end info bliss1 Ranchero & 1961 - 1967 Econoline 1 04-02-2009 06:47 AM
Brake Drum Thickness Specs Julies Cool F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-13-2008 12:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
