I cut the glass for my chop top today and...........
IT BROKE! HAHA
BUT
Now, I had nothing to lose. The glass was delaminating around the edges and I am buying new anyhow. I called a guy (Chris Blattie) to cut it for me and is sure he can he just needed a paper template. I will fit my cab to the glass I cut. and then make a paper template and mail it to him for him to cut.
I called my local guy and he assured me it would break if he cut it down for my template, and was going to charge me 50.00 bucks to do it.
I thought I can do it myself, and was going to order a glass wheel/pen. Then it dawned on me, back when I did construction we used to cut glass wheels with a diamond blade on a grinder when we had tight spots, so why wouldn't it cut a windshield......well it does and did
I was doing it outside in 30 degree weather, the glass was really old and brittle, I was using a cheap blade, trying to hold a water hose and an angle grinder at the same time, I was in a hurry, and it was nearly dark.
So I come away with this, It is possible to cut a windshield with the grinder and diamond blade. I will probably try my own instead of paying someone else to do it. Had I had someone holding the hose so I could have controlled the grinder I wouldn't have cracked this one. And it can be done within about 15 minutes
I taped it off
used this blade
taped it off
and cut it
BUT
I taped it off
used this blade
taped it off
and cut it
You are going about the chop in the correct manner...cut the glass and THEN match the roof to it. As you can see the point where the glass meets the roof is considerably forward. The good news is that the 56 roof has enough "brow" to compensate for the new position of the windshield. Good luck with your project!
Received 4,130 Likes
on
You are braver than I am, not in the fact that you cut the glass but the attempt of chopping a 56 or anything with the wrap around windshield. I may be wrong but there looks like there will be a rather large gap at the top of the glass when the roof is lowered. I've tried visualizing this many times and why I'd be afraid to try it. Waiting to see how it turns out. Another reason why I think I'd not attempt it is because of the agony of having to do it all over again should a flying rock makes contact with it in the future which would be my luck.
on
on
56, you are right. The solution is to sand off the back upper edge of the wing, and lower bottom edge of wing to allow the glass to roll back.
I have decided not to do the chop. I really like the look of the flattened roof with the stock height cab as I have done.
BeholdenZippy
02-24-2020 07:26 AM
3twinridges
03-23-2019 09:58 AM
bryanmartin
09-06-2018 11:18 AM
abe
25
05-05-2018 06:58 PM
