1950 F-1 Under Floor Master Cylinder Questions - Ford Truck Enthusiasts Forums
Old 02-15-2014, 02:08 PM
dick1950 dick1950 is offline
dick1950 is starting off with a positive reputation.
Hello,
Haven't been on here for a while. I've been after working on friends restoration of a 56 Crown Vic. It's time I resume working on Effie, my 50 F-1. I have some brake questions.
Let me tell you about the truck
1988 Mustang 302 V-8
T-5 Transmission
1998 Explorer 8.8 Rear End (3.27)
Gibbons front end (1970 Chrysler tortion bar system)
Disc brakes front and rear.
I plan on using a IDIDIT or Flaming river Steering column
Questions
Do I need a booster or will a non booster MC do the job.
Do you recommend Underfloor or firewall Master Cylinder (I doubt a booster version would clear the tortion bars and I question the available room under the hood with the headers, AC etc.)
Is there such a thing as a under floor MC that does not have a hydraulic clutch?
Recommendations as to which unit to buy.
Any pictures of your installation would help.
Thanks a lot,
Dick in Southwick, MA
Old 02-15-2014, 02:49 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I think if it was me, I'd look for a set of Mustang hanging pedals and utilize the firewall mount booster and m/c from the Mustang, along with the cable clutch set up they come with. That would make life much simpler in the long run to make everything work. Torsion bar suspension definitely has its drawbacks, and room for underfloor stuff is one of them.
Most of us are used to driving modern cars with power brakes, so going backwards might take some getting used to whenever you drove it with manual brakes needing the extra pedal effort. The booster and m/c would be high enough on the firewall so there shouldn't be any clearance issues with the engine. It all depends on how you set everything up, I suppose.
Old 02-15-2014, 06:11 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
This looks like a good unit. It moves the booster back, looks like 5". Front of bracket bolts to old master cylinder location so it is further from the narrow point between the transmission and frame. It's what I'm planning on using on my 52.
CPP 1948 52 Ford F100 Pickup Power Brake Booster Kit for 4 Wheel Disc 4852BB4 | eBay
Old 02-15-2014, 11:16 PM
TireDood's Avatar
TireDood TireDood is offline
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
I'm using something very similar in my 51. Bought the booster/mc combo from Speedway, Wilwood prop valve, and residual pressure valves. I fabricated the mounting bracket rather than buy one. If you have any fabrication skills the bracket will be pretty easy, and you can build it to fit your frame/suspension setup.
2011-2012 Master Cylinder Question 49fordv8f4 1999 to 2016 Super Duty 0 07-18-2016 12:19 PM
49 F1 brake booster M/C Murb 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-23-2015 12:39 PM
Ididit/Flaming River Steering Column Choice dick1950 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 09-18-2012 08:06 PM
'51 F1 disc brake conversion - trouble bleeding new Master Cylinder 51-f1-bob 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-19-2012 12:29 PM
Brakes,replaced everything,still bad..help! 78COBRAII Brakes, Steering, Suspension, Tires, & Wheels 3 03-22-2006 11:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
