99 Transfer Case Question - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-15-2014, 11:59 AM
Macs1964F100's Avatar
Macs1964F100 Macs1964F100 is offline
Macs1964F100 is starting off with a positive reputation.
I am considering buying a 99 6spd 7.3 4x4 DWR with 250k miles. The front prop (drive) shaft is missing. The used car dealer has no explanation other than, it could have been the shaft, or the front differential, or the transfer case.
Is there a common failure point for this model and what type of parts bill could I run into fixing the 4x4? Is the transfer case for the 6spd the same as the other transmissions?
I only need the 4x4 to cover a mile of muddy road when it rains about 10 time a year. I need it functional but not perfect.
Old 02-15-2014, 12:31 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
you should be able to test the transfercase by putting in 4x4 & test drive.the front axle could get tested by locking the hubs & test driving,confirm the hubs locked by trying to turn the axle shafts next to your balljoints,also give tthe front diff. pinnion a shake.
Old 02-17-2014, 10:46 AM
Thank you for the tips. I was on my way to look at the truck and they lost the keys. I will try to see it again this week end.
What do i need to do to make my truck 4 wheel drive Muddog99 1961 - 1966 F-100 & Larger F-Series Trucks 5 12-29-2013 06:10 PM
99 Expy shift motor socket does not line up with transfer case shaft vtgboss Expedition & Navigator 27 12-18-2013 01:22 PM
Would you stay away from purchasing this truck? (Transfer case problems) MichiganMikey 2004 - 2008 F150 4 06-25-2013 04:30 PM
transfer case front shaft leak Black Ford XLT 1978 - 1996 Big Bronco 2 02-02-2011 09:14 AM
Transfer case help 03XLT4x4 Flareside Explorer, Sport Trac, Mountaineer & Aviator 1 12-21-2004 09:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
