e4od tach sensor,
Old 02-15-2014, 08:35 AM
banicman's Avatar
banicman
banicman is offline
e4od tach sensor,
i swapped the 351 windsor for the 6.9,, my problem is how do i send a message to teh tranny so that it can read the rpms of the motor. on the 6.9, the sensor has two wires coming out on top of the ddrive gear for the injector pump, is there a way to splice them into the wirin g of teh truck, with looking at the wiring diagram of the truck. the truck is 92 f 350. teh truck moves , but only has second and drive movement, and no overdrive. I believe the tranny is not sensing the rpm. any help would be great, better fuel milage.
Old 02-15-2014, 08:56 AM
banicman's Avatar
banicman
banicman is offline
my bad
i forgot i asked this question before, i got replies, i just drive teh truck around the farm, until i fix the problem. wiring diagram are tough to read, but will conquer in the end.
Old 02-15-2014, 09:37 AM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Just what are you working with? The Windsor transmission sure didn't bolt up to the 6.9, and the 6.9 never came with the E4OD. Did you get an E4OD off of a 7.3?
bnate
16
02-16-2010 11:27 PM
rupejosh
03-07-2009 04:14 AM
94_IDI
09-09-2008 11:23 PM
turbonitrous
03-03-2006 09:02 AM
Quick Reply: e4od tach sensor,
