300 cic NY taxi proven, did maintenance on Divcos with a zillion hours idling all
under 15 mph all day - never had one come undone..... my vote YES..............
Thanks. I'll check into that crossmember. I like the way you made your clutch linkage. I wonder if I could modify the swing pedal assembly from the 96 and put in the 56 similar to yours. Then I think I could use the factory clutch master cylinder as you did. Did you use the plastic factory tubing for your clutch? Thanks again, Greg.
Glad I could help out and thanks for the compliments. The factory tubing fit just fine.
I'm almost ready to finish weld the steel flatbed I'm making for this truck. All I have left to do is finish the support pieces that go underneath the angle iron and still need to lay out the headache rack.
Dang, that flatbed looks awesome, just like it could've come on the truck, great job, I also love the way you integrated the pedal pads into the new pedals, makes it look more "right", great build
