300 big six in a 1953 f250
Thanks for your compliment, and that yes that is a factory cutout in the valve cover. I believe only efi motors were fitted with that type of cover.
Well, after much research I decided that a late model clutch pedal setup was not what I wanted for this truck, so I just made one. I had previously bought the firewall mounting brake master cylinder setup from mid fifty so I just made a longer bolt and added some bracing for the clutch master cylinder.
UPDATE:
First of all, i do not have the budget to get my truck professionally painted, let alone for the material itself. Therefore, I just spent $200 on rattle cans and got after it. I figure that this will at least keep it from rusting long enough that I can save up for a professional paint and body job.
Unfortunately, while I was moving the truck around, the steering gear finally gave way. I am now in the process of deciding what steering kit to buy to replace it. This truck is going to we a work truck so I think I might go with midfifty's new power steering kit. I just would like to keep my original steering column which I'm not sure is possible with the above mentioned kit. As always, any input is welcomed.
UPDATE:
I've seen some nice rattle can paint jobs. As long as you did a good prep job it should be fine. I think the biggest issue most people have with rattle can jobs is they just don't apply enough coats. I've done a few in my past. Including one that I also rattle canned clear coat on and wet sanded and polished it. It shined so much you had to wear shades to look at it!
Are you talking about the their toyota power steering set up? If you are you can use your stock column. But it requires some modifications to the end of the column. I believe you have to cut the column and center shaft off your stock set up. Then trim the outer tube back some and install a bushing or bearing. Midfifty's has all the parts and instructions to do it.
The truck is looking good! Keep up the good work. I've seen some nice rattle can paint jobs. As long as you did a good prep job it should be fine. I think the biggest issue most people have with rattle can jobs is they just don't apply enough coats. I've done a few in my past. Including one that I also rattle canned clear coat on and wet sanded and polished it. It shined so much you had to wear shades to look at it! Are you talking about the their toyota power steering set up? If you are you can use your stock column. But it requires some modifications to the end of the column. I believe you have to cut the column and center shaft off your stock set up. Then trim the outer tube back some and install a bushing or bearing. Midfifty's has all the parts and instructions to do it.
I didn't even know they had that system. But yes you can use the stock column. It's the same deal I mentioned above about the toyota system. They sell a rag joint for the 400 series swap to use the stock column.
#28
Thank you. Now I'll be able say that I've got all ford and aftermarket parts. Haha no manufacture mixing for me
#29
UPDATE:
That rattle can job looks fantastic.
#30
