89 F350 unknown wires - Ford Truck Enthusiasts Forums
Old 02-14-2014, 10:37 PM
AirMakesMeCrazy's Avatar
AirMakesMeCrazy AirMakesMeCrazy is offline
AirMakesMeCrazy is starting off with a positive reputation.
Just picked up a '89 F350 Custom with the 7.3l IDI… This is my first diesel truck. This truck had been sitting for a while and pretty much started right up to drive it on to the trailer. We changed the fuel, oil and air filters so far.
I really like this site and find it very interesting.
As I explore the truck and get it road worthy, I came across some connectors without a home. Hoping someone here can identify the connectors and steer me in the right direction.
The first is a blue wire that is near the fuel filter…
This wire/connector is near center of the engine block, behind the oil fill…
Any help is appreciated
Old 02-14-2014, 10:51 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
That first wire most likely goes to the water sensor that should be on the bottom of your fuel filter/water separator. Some one may have changed the filter to a style that doesn't use the sensor. The correct one will have a large cap that screws onto the bottom of the filter with the sensor and a drain ****. Nothing wrong with the other way, just eliminates the possibility of a leak from that cap.
I think the second plug goes to an A/C compressor...but not 100% sure.
Old 02-14-2014, 11:07 PM
finitetime finitetime is offline
finitetime is starting off with a positive reputation.
Quote:
I agree. That was my first thought.
[/quote]I think the second plug goes to an A/C compressor...but not 100% sure.[/quote]
Not real sure mines a 93 and the connector looks a little different but I think you go this one right too.
Old 02-14-2014, 11:18 PM
In the same wire loom as the blue wire I'm trying to Identify, is the wire that goes to the bottom of the fuel filter… I think that one connects to the "water in fuel" sensor. That sensor seems to work because it was lit, and after we changed the filter it went out. And I don't have A/C
Old 02-15-2014, 07:52 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
does your cold high idle work?
the temp sensor for the high idle timing advance in under the alternator.
i don't remember if it is a one wire or 2 wire connector though.
it may also be a glow plug connector for the passenger front cylinder.
Old 02-15-2014, 12:28 PM
The cold idle seems fine... Fires up, and then kicks down after a bit, so that seems right to me.
I will look around the alternator and the glow plugs a little more later today. Work, before play... Sucks.
Old 02-15-2014, 12:47 PM
i ain't rite
if the cold high idle works, than it is not the temp sensor wire.
Old 02-15-2014, 09:44 PM
Okay… This is what I've got. My mystery connector is on a blue wire that is in the same wire loom as the black wire going to the top of the fuel filter housing. The glow plug located under the fuel filter has a connector going to it.
It's a mystery, that's for sure
1978 F150 5.3 LM7 Swap Rossta86 Engine Swaps 44 12-27-2016 07:33 PM
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 05:20 AM
Backup Speaker over ride switch install - For Dummies sammie0126 Excursion - King of SUVs 10 11-16-2013 11:12 PM
Car show in Bangor Maine, my dent took 2nd taxreliever77 1973 - 1979 F-100 & Larger F-Series Trucks 11 09-12-2010 03:14 PM
The 2009 FTE Ford Truck Championship FINAL ROUND Greywolf General Automotive Discussion 217 01-06-2010 02:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
