460 idling high
460 idling high
So driving my truck home today, f350 in sig with 460ci and 51k miles the coolant temp gauge never reached where it should be at operating temp, I drove the truck 35 miles home with outside temp 28*F the temp needle was about halfway between the C and N(for normal on gauge) the cab had good heat though.
Another issue is even after driving the truck 35 miles it idles high, in park it idles at about 1000 rpm and in drive its probably 900rpm
I have a feeling what going on here is that the computer thinks the truck is cold so its sending it into high idle, Could this be a faulty coolant temp sensor? I tried searching but cant find solid information, also in my searching it appears there are two coolant sensors, one temp sensor is for the computer and another is for the gauge but maybe those were for older efi 460's
could this be why my truck is constantly idling high?
I watched a YouTube video about this basically I jump the wires then turn the key on and count the CEL flashes
What is cm mode display
Ok I tried counting the codes, I belive I have as follows
563- high speed electro-drive fan circuit failure
663- 4wd switch closed
411- cannot control rpm during koer low rpm check
I tried to take a video so maybe you guys could help me decode but I cannot upload it, also got the system pass 111 code
I dont feel any of these codes pertain to my 1000rpm idle concern
I started the truck and let it run a couple minutes, I then unplugged the IAC valve under the throttlebody, the truck bucked for about 5 seconds then died, that is good right? could that tell me its not pulling air elsewhere like with a vacuum leak
Ok I got the video uploaded here is a link to a video I took of all the codes flashing because I'm sure I missed one or counted wrong even though I did the koeo test 5 times and counted over and over
this is where the truck was idling today just below 1k mark now
[IMG][/IMG]
and I also found this thing blowing air out toward the fender
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
ok some new info, I removed the bat cables to clear codes, replaced both coolant temp sensors and put a new 195* tstat in
truck now gets to operating temp and the temp gauge works, but the high idle problem is still there, it goes up and down also, in park it will slowly drop to maybe 800 rpms then go back up to 1000rpm
with truck cold unplugging iac valve truck runs for about 5 sec then dies
truck at operating temp unplugging iac valve truck will run for maybe a little more than a minute but rpms drop to about 750, and then slowly drop to around 450 until it chugs and dies
I did notice your tach did not read Zero with the truck off?
Personally I have not had any success using the spray method to find a vacuum leak on a fuel injected engine. I find testing each vacuum circuit with a handheld vacuum pump/gauge is the only to know for certain.
If the PCM is sensing a lean condition, caused by unmetered air aka vacuum leak, it will dump in fuel to compensate.
